Print at Aug 21, 2026, 10:58:05 AM
Posted by gp13 at Feb 5, 2013, 5:05:36 PM
No menu "level1/level2 +" under MACOSX
Hello and Bonjour,
I have a fresh new Mac Book, the latest OS.X, and I believe the latest SH3D version :
Sweet Home 3D ® Version 3.7 Version Java 1.6.0_37
I do not have the little menu to select my level 1 or 2 I made, so I cannot modify Level2 at the moment, and can only access level 1.
Any idea "why" and "how to fix ' this ?
Many many thanks.
Best.
Gilles
Posted by Puybaret at Feb 5, 2013, 5:39:45 PM
Re: No menu "level1/level2 +" under MACOSX
To avoid encumbering the user interface and troubling new users with too many features, the levels tabs appear only when the home contains at least 2 levels.
Did you add at least one level with the Plan > Add level menu item?
Posted by gp13 at Feb 6, 2013, 5:24:37 PM
Emmanuel,
Yes (see my message with level 1 and 2). Actually, they are many other 'bugs' under Mac OS X. I Actually I have to create new levels only to get access to the little tab. But if I select level0 for instance, all is frozen, walls etc. If I click on the left bottom windows with all the furniture, then I can get access again to the walls... But fo course, the tabs for levels disappears. So the workaround is to play with 'new level' to get access to the tab, and click to a fruniture to get access to the walls. I have also so graphic bugs - some furnitures do not appear when created. A good save/close/open put everything back. Gilles
Posted by Puybaret at Feb 6, 2013, 6:12:42 PM
The levels tabs probably disappear because the level of the selected item is not set, something that shouldn't happen as soon as you add a level.
This is clearly a bug but never found a way to reproduce it. If you find a way to reproduce it from an empty project, I would be pleased to read it.
Meanwhile, I can repair your file if you send it to me.
