Print at Sep 20, 2026, 12:04:22 AM View all posts in this thread on one page
Posted by cristeab at Feb 1, 2013, 8:47:47 PM
Inserting objects at specified location in a building plan
Hi
Is there a way to insert (manually or programatically) new objects at a given position on a building plan ? I would like to be able to specify object position in cartezian coordonates (x,y,z) and to insert or remove this object in a building plan from my own program using an API.
thanks
Bogdan
Posted by Puybaret at Feb 5, 2013, 8:37:57 AM
Re: Inserting objects at specified location in a building plan
HomePieceOfFurniture instances can be moved with their setX, setY and setElevation methods. But why programming something you can already do with the existing user interface?
Posted by cristeab at Feb 5, 2013, 9:24:57 AM
I would like to use Sweet Home 3D for object tracking inside a building.
Posted by Puybaret at Feb 5, 2013, 9:32:18 AM
Then call the methods of HomePieceOfFurniture. The listeners that are already added to a piece will automatically update its location at screen if necessary.
Posted by cristeab at Feb 5, 2013, 9:59:43 AM
Could you please provide an example of programmatically inserting and moving an object on the building plan ?
