Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Framed pictures with different motives |
| Print at Sep 13, 2026, 4:22:48 PM | |
| Posted by mife at Jan 27, 2013, 10:34:54 AM |
Framed pictures with different motives Hi there :) is there a way to have something like framed pictures with different motives? What I tried to emulate this: - a wall with texture Problem: You need for every height a new niveau - a simple mirror model with texture Problem: The texture starts from the middle Any hint apriciated |
| Posted by Puybaret at Jan 27, 2013, 11:28:46 AM |
Re: Framed pictures with different motives Are you sure you use the last version 3.7 or that you imported that texture in that version? The issue with the misplaced texture you report looks like an other one that was fixed in version 3.4. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mife at Jan 27, 2013, 1:29:57 PM |
Re: Framed pictures with different motives Version 3.7 Java version 1.6.0_37 |
| Posted by Puybaret at Jan 27, 2013, 3:30:09 PM |
Re: Framed pictures with different motives Please send me a SH3D file that contains only your object with its texture. I'll try to check the issue. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mife at Jan 27, 2013, 4:58:08 PM |
Re: Framed pictures with different motives the texture is rendered upside down!? |
| Posted by mife at Jan 27, 2013, 5:30:33 PM |
Re: Framed pictures with different motives best I could achieved Picture as texture 70x50cm, 350x250px Cube as model 70x50x50cm, Drawback: Thickness has to height of texture |
| Posted by Puybaret at Jan 27, 2013, 6:42:07 PM |
Re: Framed pictures with different motives It works for me. Look at the file attached to this message. Sorry, but keeping posting messages showing that it doesn't work for you without any SH3D file won't help me to fix a bug, in case you found one. ![]() ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mife at Feb 1, 2013, 3:15:24 PM |
Re: Framed pictures with different motives Thank you so much for your help :) Your BoxWithTexture is it! Awesome |
Current timezone is GMT Sep 13, 2026, 4:22:48 PM |
