Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Imported Textures: Vertical Alignment with Furnature |
| Print at Oct 6, 2026, 7:01:52 AM | |
| Posted by [email protected] at Jan 24, 2013, 8:52:39 PM |
Imported Textures: Vertical Alignment with Furnature I'm very impressed with the package, but have a minor issue: when I texture a door with a jpg of a door and scale the image to fit, it renders displaced down the object by about 25% (so the bottom of the image wraps to the top of the door. Any thoughts? Brian |
| Posted by Puybaret at Jan 24, 2013, 9:34:59 PM |
Re: Imported Textures: Vertical Alignment with Furnature Are you sure you are using the latest version 3.7? Because there was a bug about this in a previous version. For your information, the texture is applied from the bottom to the top of the object. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by [email protected] at Jan 25, 2013, 12:04:45 PM |
Re: Imported Textures: Vertical Alignment with Furnature Yes, I'm using version 3.7, Java version 1.6.0_37. |
Current timezone is GMT Oct 6, 2026, 7:01:52 AM |
