Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: a tool to scale the entire project |
| Print at Sep 15, 2026, 1:45:45 PM | |
| Posted by TheJoe at Dec 8, 2012, 6:24:01 PM |
a tool to scale the entire project Maybe there is already a tool like that, but i'm not aware of it, i can't find any trace on the net. Here's how i work: 1_ import the sketch file as a background (and set dimensions) 2_ trace walls and rooms 3_ place my furniture on it It's a very good way to have the job done, it takes few hours to finish even a floor.. but today i found out that the furniture was too big for that room, i went wrong when i set the dimensions on the bitmap file (the window is soooo narrow.. and there's no way to enlarge it.. maybe this could be improoved too). I find no way to correct the scale i've set. And that's how i started the same project once again... wishing to be more accurate with the scale when i import a bitmap). |
| Posted by Puybaret at Dec 9, 2012, 1:02:26 AM |
Re: a tool to scale the entire project If you want to rescale your home you can use the Advanced Editing plug-in (documentation available here). You can enlarge the import background wizard dialog with the borders of the dialog box. Sorry but I can't display the full screen button in this dialog box. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by TheJoe at Dec 9, 2012, 3:26:47 PM |
Re: a tool to scale the entire project Ummhh.. i don't think the problem is in scaling the background picture, but scaling the whole project (walls, furniture, etc.). Is this possible? |
| Posted by Puybaret at Dec 11, 2012, 7:06:20 PM |
Re: a tool to scale the entire project As said previously, please use the Advanced Editing plug-in. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 15, 2026, 1:45:45 PM |
