Print at Sep 29, 2026, 5:02:40 PM View all posts in this thread on one page
Posted by Lumaja at Nov 16, 2012, 6:33:31 AM
Sweet Home installation failure
I am a newbie with Ubuntu 12.04 LTS and tried to install Sweet Home 3d but failed.
Because I dint understand the Terminal output ask Ubuntu for help the answer follows.
It looks like you have several problems with the packages, it has unfulfilled dependencies.
Try to contact the manager of that package source because there are at list two URLs poiting to nowhere.
What should I do next to install the application successful.
Posted by hansmex at Nov 16, 2012, 12:24:40 PM
Re: Sweet Home installation failure
Luis,
When using Ubuntu 12.04 you should do the following:
- download SH3D 3.7 using the green button here or version 3.6 here.
- unzip the downloaded file.
- drag the unzipped directory where you want it.
- right-click the file SweetHome3D, choose Properties, then Permissions and make sure that you Allow executing file as program.
- ready.
Posted by Lumaja at Nov 21, 2012, 5:30:33 PM
Thank you for the help follow the Explanation but still not start
Posted by hansmex at Nov 21, 2012, 7:12:39 PM
Luis,
Please, explain step-by-step in detail what you are doing. If you get an error message, please tell us about it.
My instructions should lead to a correctly functioning SH3D.
Only exception is when you have an old graphics card or incompatible drivers. In that case read the FAQ.
Posted by Lumaja at Nov 22, 2012, 6:33:17 AM
I execute Sweet Home 3D.jar instead Sweet Home 3D only I deeply Apologize .
It is working but I have two questions.
I have an activation code, how should I activate.
How to have on Desktop an icon instead to open the directory to start the application.
Thank you for your excellent help.
Posted by DanielB at Jan 1, 2013, 8:12:11 PM
Hi Hans,
Using Ubuntu 12.04.1 LTS. SW3D used to work just fine. However, with some updates, it stopped working (was version 3.4). Decided to uninstall this version and install newest 3.7...
Since it is not available from "Logithèque Ubuntu", followed instructions here but once installed, when I open the SW, I have the SW3D boot image on but the software won't start.
Worce, the SH3D image containing :
eTeks Copyright 2007-2012
Distributez under GNU General Public Licence
is masking anyother window & I can't move it nor make it disappear...
Thanks,
Daniel
Posted by hansmex at Jan 2, 2013, 2:57:04 AM
This link should download version 3.8 beta 5.
This works on my computer, running Ubuntu 12.04.
If it doesn't work, please report what happens.
Posted by DanielB at Jan 20, 2013, 4:48:10 PM
Hi again Hans,
The link does not work:
http://www.sweethome3d.com/SweetHome3D.3.8.beta.jnlp
Daniel
Posted by Puybaret at Jan 20, 2013, 7:06:13 PM
Links to Beta versions are temporary.
Please visit this subject to get updated links for the current Beta.
