Print at Sep 20, 2026, 5:08:52 PM
Posted by John37 at Oct 28, 2012, 2:07:24 AM
Sloping ceilings not possible in multi-level buildings?
I need to create sloping ceilings above sloping walls on the 2nd and 3rd floors. However, I have found that Create rooms will create sloping ceilings only in a building with a single level. If there is more than one level in the building, it seems that Create rooms will produce only level (flat) ceilings at each level - so my ceilings always float like magic carpets above the sloping walls.
Is this a bug, please? Or am I doing something wrong?
John
Posted by Puybaret at Oct 28, 2012, 2:42:03 AM
Re: Sloping ceilings not possible in multi-level buildings?
As explained in the help, Sweet Home 3D computes slopping ceilings only at the last level, mainly for backward compatibility reasons and because this feature didn't work that well for complicated ceiling shapes. In your case, I suggest you to create a room for the floor part where you'll hide the ceiling in its room modification dialog, and a smaller room for the ceiling part for which you'll hide the floor. For the slopping part, you can add a roof 3D model, or import a box and orientate it precisely at the second step of the furniture import wizard.
