Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to add and remove part of the floor? |
| Print at Sep 20, 2026, 1:56:41 PM | |
| Posted by klgan at Oct 25, 2012, 1:48:50 PM |
How to add and remove part of the floor? Hi, How to add or remove part of the floor? For example when you have a round wall, how to add a round floor for it? The two images below should make my question clearer? Please share how to do it. Thank you :-) ![]() |
| Posted by Puybaret at Oct 25, 2012, 4:52:53 PM |
Re: How to add and remove part of the floor? Did you try to create rooms by double-clicking in the area within walls? This will take into account the round walls. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Gaytan at Oct 25, 2012, 11:31:38 PM |
Re: How to add and remove part of the floor? Hi Emmanuel, As you know I work on an iMac with latest Mountain Lion. I've got Apple's trackpad as well as Kensington's trackball mouse connected, for more precise manipulations. Double clicking within a 'closed area' in order to create rooms has never worked on my system unfortunately! Do you have any hints or tips? Kind regards, Ed |
| Posted by klgan at Oct 26, 2012, 8:05:50 AM |
Re: How to add and remove part of the floor? Good gracious! it is that simple, double click between walls... Yes it works, thank you very much Puybaret :-) |
| Posted by Puybaret at Oct 26, 2012, 10:30:02 AM |
Re: How to add and remove part of the floor? klgan, great it worked for you! Ed, maybe the areas you tried to click into weren't surrounded by a closed area of walls. Could you send me a SH3D file where it didn't work? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Gaytan at Oct 27, 2012, 12:24:22 AM |
Re: How to add and remove part of the floor? Emmanuel, Just to confirm that 'double clicking' within a 'closed area' now works. Guess it has to do with the new version? Problem solved! Rgrds, Ed |
| Posted by Puybaret at Oct 27, 2012, 12:44:51 AM |
Re: How to add and remove part of the floor? Ed, I'm glad it worked for you. I fixed a bug recently and you're right, this could be the reason why it didn't work before in your case. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Gaytan at Oct 29, 2012, 10:10:59 AM |
Re: How to add and remove part of the floor? Ok, nice!! No problem; I don't mind doing the floors and walls 'manually' but by double clicking, things do go faster; that's a fact! Nice! Thank you Emmanuel! |
Current timezone is GMT Sep 20, 2026, 1:56:41 PM |
