Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Textures Library Editor released |
| Print at Sep 19, 2026, 1:27:40 PM |
| Posted by Puybaret at Nov 23, 2017, 1:22:17 AM |
Re: Textures Library Editor released MarcoH, rotating textures can be performed only in Sweet Home 3D, not in the Textures Library Editor. From version 5.5, you can set any angle. SnakeGB, I'll see if I can improve the naming system in a future version of the Furniture Library Editor. Campi, the Jar executable files shouldn't be unzipped, run them with Jar Launcher. Note that I don't think that the Furniture Library Editor can run with Java 9 under macOS at the moment, and you should rather run it under Java 8. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Campi at Nov 23, 2017, 4:14:37 PM |
Re: Textures Library Editor released Thanks Puybaret I've done some research since I posted and indeed el captain with java 9 has caused some problems with jars. For some reason 10.11 does not have the launcher from what i understand. My next hurdle will be to to uninstall 9 (as it seams you can't install older versions over newer) since I'm not that proficient with the terminal haha Thank you for the link since apple no longer supports legacy java Thanks again |
| Posted by Campi at Nov 23, 2017, 5:11:35 PM |
Re: Textures Library Editor released OK that did the trick java 8 installed. The jars still show as zip files but at least I can open with terminal. Thank you Puybaret!! |
| Posted by Campi at Nov 24, 2017, 6:05:09 PM |
Re: Textures Library Editor released Hi Again I know I am missing something but just can't seem to get it to work. I know this is a java/os problem but perhaps you might have some insight. I got the texture and the furniture editors to open using the terminal but when I try to open a library I get nothing in the texture editor and the furniture editor crashes when opening a furniture lib. I have tried all the versions of the editors and same thing happens. I know this works because the furniture editor worked fine with 10.8 Again, any insight would be appreciated |
| Posted by Puybaret at Nov 24, 2017, 6:51:06 PM |
Re: Textures Library Editor released What Java version is displayed in the About dialog (click on the light bulb at the end of the toolbar)? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Campi at Nov 25, 2017, 5:13:44 PM |
Re: Textures Library Editor released 1.5 for the Texture Lib Java version 9.0.1 I have also tried 1.3 and 1.4 both indicate Java 9.0.1 |
| Posted by FPatrick at Mar 31, 2020, 5:53:48 PM |
Re: Textures Library Editor released Bonjour, SH3D est toujours aussi plaisant à utiliser, Merci ! Je viens de mettre à jour Textures Library Editor avec la version 1.6. Mon système d'exploitation est Xubuntu, java version 11.0.6 est installé. Je lance le soft sans problème, j'accède au menu « Ouvrir une bibliothèque de textures », je sélection une bibliothèque créée il y a deux ou trois ans (Ma_Bibliotheque_textures.sh3t)... et rien ne se passe. Une idée ? Merci par avance ! |
| Posted by otadmin at Sep 5, 2020, 3:59:53 PM |
Re: Textures Library Editor released Has there been a solution to the problem? I am on Jave 11.0.8, LinuxMint 20 and the same happens here - empty texture editor. |
| Posted by otadmin at Sep 21, 2020, 8:37:08 AM |
Re: Textures Library Editor released Solved my problem by installing Texture Editor 1.6 from the Sweethome website. Version 1.6.2 in the repositories of LM20 not working. |
| Posted by Soulbrother at Jul 27, 2022, 3:40:12 PM |
Re: Textures Library Editor released A wish: could you integrate the category in the Preferences, so that we can setup a category (new or existing). OR is there any other way, to avoid manual choosing and entering for each texture in one lib.? |
Current timezone is GMT Sep 19, 2026, 1:27:40 PM |
