Print at Sep 19, 2026, 9:00:11 PM
Posted by jfs51765 at Sep 6, 2012, 1:18:08 PM
2nd level walls
Good day, i am planning to renovate my house with a basement level, my problem is how can i create the walls of the basement and ground level walls with different dimensions & location as well as the ground perimeter walls, i have downloaded and installed all the software at the download section.
How will i create the ground level on top of the basement level, thanks in advance for the assistance, newbie here.
Posted by hansmex at Sep 6, 2012, 3:40:34 PM
Re: 2nd level walls
Joey,
Use the function Levels with a negative elevation.
Posted by jfs51765 at Sep 7, 2012, 4:47:30 PM
Re: 2nd level walls
Sorry sir but i cant find or dont know how to go to or use the function levels, can you point me to a more precise instruction, i just so happen to use the program for the first time, thanks again for your kind assistance.
Posted by hansmex at Sep 7, 2012, 8:23:42 PM
Re: 2nd level walls
Joey,
Did you read this section in the online User's Guide...?
Posted by jfs51765 at Sep 8, 2012, 9:58:16 PM
Re: 2nd level walls
Sir,I just so happen to the section your pointing out here, reason why i can find the split level thing is that i have installed the old version, when you replied about the split thing and cant find it i then tried downloading the latest version and now i am learning more in using the latest version and was able to toy around split level or adding new level.
Again Sir thank you very much for your very kind assistance, i am still in the process of learning what i can do with this free software.
