Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: copy the library with the textures that I created on my pc to another computer |
| Print at Aug 14, 2026, 6:38:36 AM |
| Posted by mundo0007 at Aug 31, 2012, 5:00:34 PM |
copy the library with the textures that I created on my pc to another computer I need help. I can not copy the library with the textures that I created on my pc to another computer. I did what was described in this forum but not worked. I have many maps created and I can not lose them. Where are these files? |
| Posted by Puybaret at Sep 1, 2012, 1:41:25 PM |
Re: copy the library with the textures that I created on my pc to another computer If you're under Windows Vista/7, please see this thread. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mundo0007 at Sep 4, 2012, 4:37:02 PM |
Re: copy the library with the textures that I created on my pc to another computer Hi, I have this path in my pc with Windows XP : C:\Documents and Settings\aacorreia\Application Data\eTeks\Sweet Home 3D this directory are several files *. pref but the directory \ textures - This is empty. I copied the *. pref for the pc that has windows 7 but they do not appear in the library of textures. what could be wrong? |
| Posted by Puybaret at Sep 4, 2012, 5:36:24 PM |
Re: copy the library with the textures that I created on my pc to another computer textures directory contains SH3T files so it's not a problem. what could be wrong? You have to copy the preferences.xml file too. If the destination computer runs Windows 7, the destination directory should be C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D where user is your user name. Caution! Once preferences.xml is copied on the destination computer you'll will loose all the furniture and textures you imported on that computer. So create a backup of Sweet Home 3D directory first. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mundo0007 at Sep 27, 2012, 4:55:05 PM |
Re: copy the library with the textures that I created on my pc to another computer Thanks, problem solved... |
| Posted by Gaytan at Oct 22, 2012, 1:36:21 AM |
Re: copy the library with the textures that I created on my pc to another computer And what happens if you're on a Mac? I notice that when I copy my whole folder with all libraries, project to USB stick to then work on that on my Macbook, once copying everything back to my Mac, my changes are lost as well! Which file, where, to copy as well? Guess in the 'Application Support' library? Only .xml? |
| Posted by Puybaret at Oct 22, 2012, 10:09:16 AM |
Re: copy the library with the textures that I created on my pc to another computer The content of the eTeks/Sweet Home 3D is portable from a computer to another one and across different operating systems. The difference from a system to another is the name of this folder and where it should be found: - under Windows Vista / 7 / 8 / 10, this folder is C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D, - under Windows XP and previous versions of Windows, this folder is C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D, - under Mac OS X with the free version, it's the subfolder Library/Application Support/eTeks/Sweet Home 3D of your user folder, - under Mac OS X with the Mac App Store version, it's the subfolder Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D of your user folder, - under Linux and other Unix, it's the subfolder .eteks/sweethome3d of your user folder, - under the portable version, it's the subfolder data of the folder that contains Sweet Home 3D applications. Under Mac OS X, to ensure you pick the right eTeks folder, you can open a new window in the Finder, select Go > Go To Folder menu item (cmd + Shift + G shortcut), and enter the folder ~/Library/Application Support or ~/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D (with the ~ tilde sign prefix) ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Gaytan at Oct 22, 2012, 1:36:41 PM |
Re: copy the library with the textures that I created on my pc to another computer Emmanuel, Thanks for pasting my info! In the subfolder you mention (on Mac) there are only .pref files. No xml! I'll test to see if things go better with copying the mentioned folder as well! Thanks for your effort! Kind regards, Ed |
| Posted by Puybaret at Oct 22, 2012, 3:03:02 PM |
Re: copy the library with the textures that I created on my pc to another computer From version 3.0, preferences.xml file is necessary and .pref files alone are useless. What version of Sweet Home 3D do you use? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Gaytan at Oct 22, 2012, 3:11:45 PM |
Re: copy the library with the textures that I created on my pc to another computer Hi Emmanuel, Version 3.6; found the preferences.xml alright! It was right in the middle of all the .pref files! Sorry! Will copy both folders completely to put on my Macbook in future; not only the 'working folder'... Thanks for your info! Kind regards, Ed |
Current timezone is GMT Aug 14, 2026, 6:38:36 AM |
