Print at Sep 13, 2026, 11:28:56 PM
Posted by macfrog at Aug 17, 2012, 10:58:50 PM
Wooden Beams, Roof Support etc. (Holzbalken etc.)
Hello,
here is a short HowTo create objects like beams, wooden substructure in old houses and so on. This time we don't use the "Box".
the picture below shows the first step pretty clear: you create walls with the dimensions of the wanted structure, like 5 meters long and 20by20cm in thickness:
these "walls" can be exported as OBJ and then re-imported to the furniture library in SH3D, preferably in an own category to find it back easily. Make sure, you use proper dimensions and angle while importing!
macfrog
Posted by kbon at Aug 18, 2012, 6:27:11 PM
Re: Wooden Beams, Roof Support etc. (Holzbalken etc.)
Thanks :) I already did it this way for my roof rafters, figuring this would be the right way, after reading the "how to make a roof" tutorial :)
Just to make this tutorial complete (for starters who don't know about it): You need to "copy as new furniture" the walls first (sh3d plugin), paste it in a new home and then export
Posted by macfrog at Aug 19, 2012, 8:12:07 PM
Yes kbon,
i forgot to mention this :-)
otherwise you're creating a "floor" panel behind those beams...wouldn't like that ....
macfrog
