Print at Sep 11, 2026, 3:10:06 AM
Posted by Fruto at Aug 12, 2012, 12:27:29 AM
Help Please! Can't load 3D model on browser
Firstly, thank you so much for making this program! It is awesome - love it!
I am really new to this and also new to website (basically, self-taught in IT). So, I downloaded the SweetHome 3D Viewer 3.5 (and SweetHome Installer 3.5), designed a 3D model, "save and compress", then changed the html file and transfer it to webserver via FTP - but I can't even the test file didn't work.
It says "Can’t open home http://www.webppdp.com/TrialH.sh3d"
But I kept going and load the whole lib folder as subdirectory and the TrialH.sh3d file over the FTP - and the error is now:
"Can't start applet: Exceptionjava.lang.NoClassDefFoundError.javax/media/j3d/GraphicsConfigTemplate3D"
Can you please help?
O, and also, my web server hosts is an API server, does it make a difference?
Is there anyone in the same situation as me for Viewer 3.5?
Posted by Fruto at Aug 13, 2012, 4:19:45 AM
Re: Help Please! Can't load 3D model on browser
O, and I have read through other threads with similar problems but nothing worked for me...
Also, another question, when my friends view throught their browser, do they need at least Java v7 in their OS?
Posted by Puybaret at Aug 13, 2012, 11:35:27 AM
The file in you URL http://www.webppdp.com/TrialH.sh3d can't be found. Thus I guess you didn't build correctly the URL from the server where you hosted your files, or you didn't set the file rights correctly on the server.
When my friends view throught their browser, do they need at least Java v7 in their OS?
They need at least Java 5.
Posted by Fruto at Aug 13, 2012, 2:10:35 PM
Thanks for the prompt reply.
Sorry, the webpage is:
http://www.webppdp.com/TrialH.html
For which I changed in the html code to:
homeURL:"http://www.webppdp.com/TrialH.sh3d"};
And put the TrialH.sh3d file in the same folder as the TrialH.html
And copied the whole "lib" folder in the above folder too.
Where do I go wrong?
Thanks
Posted by Fruto at Aug 15, 2012, 8:34:11 AM
Hi all!
Problem solved! Yay - and this is for all future users experiencing similar problems too:
Call up your website server and ask them to add .sh3d file (and .jar file too if they don't have it) extension on the server.
Basically, nothing wrong with Sweet Home 3D Viewer, it's the server that doesn't know how to read the file.
(This happens because I am with a small/cheap server)
Thanks for the program!
Fruto
Posted by Fruto at Aug 17, 2012, 3:12:20 PM
Just another general question...
I found that when exploring the 3D model over the browser is lagging when I view using my laptop, but perfect speed when I use my desktop.
Is this something to do with the graphic card?
Posted by Puybaret at Aug 17, 2012, 3:42:34 PM
It might be. How old is your laptop?
Posted by Fruto at Aug 18, 2012, 2:33:10 AM
I think it's 2007. It runs on Windows Vista.
Just tried it on Mac yesterday - it works too! (after a quick install of Java). But still not very smooth when rotating the model...
Posted by Puybaret at Aug 19, 2012, 11:20:10 AM
Maybe your home contains too detailed 3D models or too numerous models like trees?
Could you send me your file so I check?
Posted by Puybaret at Aug 28, 2012, 7:32:33 PM
I tried the files you sent me, and under Windows 7, I noticed some performance problems in Virtual visitor mode during a 3D navigation, when the plan view is visible. As soon as you hide the plan view, the program works better. This make me think it's a problem in how the plan is updated. I'll try to check where the problem comes from.
Posted by Puybaret at Aug 28, 2012, 8:32:48 PM
I tried again under Windows XP and it worked much better. Maybe a driver issue?
Note that the tests I run under Windows are with a virtual machine not a real PC (I have only an iMac).
Posted by Fruto at Aug 29, 2012, 7:18:41 AM
Maybe I delete the 2D plan (rather than just hide it) will make the performance better
Posted by drlmodern at Dec 3, 2012, 7:19:34 PM
hey there im new to all this and really not technical
1 my question is after i have crated a home on my desktop how do i then transfer to my laptop to work on the go ,
2 is there a way to also save the file from the desktop to the online version so i can vue it from anywhere?thanks in advance!
Posted by Puybaret at Dec 3, 2012, 7:59:44 PM
1 my question is after i have crated a home on my desktop how do i then transfer to my laptop to work on the go,
Just copy the SH3D file to the other computer and install Sweet Home 3D on it.
No, but you can view the file on any computer where Sweet Home 3D is installed.
