Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rotate part os a projec |
| Print at Sep 19, 2026, 10:21:18 PM | View all posts in this thread on one page |
| Posted by Clovis at Jul 26, 2012, 12:13:53 AM |
Rotate part os a projec Is possible to rotate only a part of a project, includin some walls (their are not atached to the part that I dont want to rotate, I will atach after rotating) Thanks Clovis |
| Posted by macfrog at Jul 27, 2012, 12:52:55 AM |
Re: Rotate part os a projec Clovis, it depends: do you mean furniture as well or just some walls and rooms? In general, you could select all you need and copy it to the clipboad and paste this part to another empty project and rotate this part of the plan. this can be used for walls and rooms. hint: if you want to detach one wall from another, you just cut/paste the selected wall onto the very same spot (helpful for splitted wall segments). the furniture has to be grouped together and rotate as on single object, later to be ungrouped of course. macfrog |
| Posted by Puybaret at Jul 27, 2012, 8:38:25 AM |
Re: Rotate part os a projec Maybe you could try also to use the Advanced Editing plug-in described in this document. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 19, 2026, 10:21:18 PM |
