Print at Sep 20, 2026, 6:23:41 PM
Posted by ndhduong at Jun 27, 2012, 1:22:58 PM
Version 3.5 - Old data build up issue
Thanks for creating a great program. I have been using it for a week and found it to be very useful and interesting.
The version I use is 3.5. During my usage, I have been importing and removing models many times. After a about a week, the Application Data\eTeks\Sweet Home 3D\work folder grew to over 4GB! Upon more careful inspection, I realized that when you delete a newly imported model, the program does not delete the associated zip file it created earlier. Also, it does not delete those files after I uninstall the program (moderate uninstall using revo uninstaller). So when I reinstall the program or re-import the model, it keeps adding more files (of the same models) to it.
This can be a major issue in a long-run.
By the way, if the imported models are saved in \furniture and \work folders, where are the default furniture (those that preloaded when you install the program) located?
Thanks
Posted by Puybaret at Jun 27, 2012, 2:45:39 PM
Re: Version 3.5 - Old data build up issue
Please read this thread.
Posted by Puybaret at Jun 27, 2012, 2:46:42 PM
The default furniture is in resource files with the program executable.
