Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: not compatible application version |
| Print at Sep 19, 2026, 7:36:26 PM | View all posts in this thread on one page |
| Posted by adampease at Jun 10, 2012, 5:43:00 PM |
not compatible application version When starting up sweethome3d on Ubuntu Linux, with several of the plugins, I'm getting the message Invalid plug-in jar:file:/home/apease/.eteks/sweethome3d/plugins/CopyAsNewFurniture.sh3p!/com%2Feteks%2Fsweethome3d%2Fplugin%2Fcopyasnewfurniture%2FApplicationPlugin.properties: Not compatible application version Could someone advise? |
| Posted by Puybaret at Jun 10, 2012, 6:08:43 PM |
Re: not compatible application version What version of Sweet Home 3D do you use? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by adampease at Jun 10, 2012, 7:39:24 PM |
Re: not compatible application version It's version 2.6, which is the version that installs from the Ubuntu Software Center |
| Posted by Puybaret at Jun 10, 2012, 7:46:20 PM |
Re: not compatible application version Use the latest version 3.5. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by adampease at Jun 10, 2012, 8:50:52 PM |
Re: not compatible application version Thanks Emmanuel, using the latest version solves the problem. Maybe someone could update the version in the Ubuntu repository. That will help other newcomers. Many thanks for the excellent software! |
| Posted by adampease at Jun 10, 2012, 9:10:54 PM |
Re: not compatible application version Well, I may have spoken too soon. I now get a JRE crash, as well as some messages about other plugins being invalid. This is all while trying to follow the "sloping ceiling" tutorial. The crash happens while attempting step 8 on page 8 of the tutorial Furniture->import furniture . I can replicate the crash. apease@apease-HPdm:~/Programs/SweetHome3D-3.5$ ./SweetHome3D Invalid plug-in jar:file:/home/apease/.eteks/sweethome3d/plugins/RotateHomePlugin.zip!/RotateHomePlugin%2Fsrc%2Forg%2Faddy%2Fsh3d%2Fplugin%2FApplicationPlugin.properties: org.addy.sh3d.plugin.RotateHomePlugin Invalid plug-in jar:file:/home/apease/.eteks/sweethome3d/plugins/DuplicateStylePlugin_version4.zip!/DuplicateStylePlugin_version4%2Fsrc%2FnewPlugin%2FApplicationPlugin.properties: newPlugin.CopyStylePlugin # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x00007fcd8ea86b24, pid=9121, tid=140520710752000 # # JRE version: 6.0_32-b05 # Java VM: Java HotSpot(TM) 64-Bit Server VM (20.7-b02 mixed mode linux-amd64 compressed oops) # Problematic frame: # C [libGL.so.1+0x25b24] __float128+0x64 # # An error report file with more information is saved as: # /home/apease/Programs/SweetHome3D-3.5/hs_err_pid9121.log # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # Aborted |
| Posted by Puybaret at Jun 10, 2012, 11:56:28 PM |
Re: not compatible application version Maybe someone could update the version in the Ubuntu repository. Sorry I take care only of versions delivered on SourceForge.net. Please contact Ubuntu team directly.Sorry for the crash, it generally means an issue with the video driver. Hope you can fix it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by adampease at Jun 11, 2012, 12:31:13 AM |
Re: not compatible application version Hi Emmanuel - Just to be clear, the current issue with the crash is with the version from SourceForge.net - version 3.5. |
| Posted by adampease at Jun 11, 2012, 1:38:33 AM |
Re: not compatible application version I've replicated the problem also now with both JRE 6 and JRE 7. I've reported the bug to Oracle and will let you know if their feedback indicates that any change in use of Java is needed. |
Current timezone is GMT Sep 19, 2026, 7:36:26 PM |
