Print at Sep 19, 2026, 7:09:10 PM
Posts: 19   Pages: 2   [ 1 2 | Next Page ]
Posted by mikeycast at May 24, 2012, 11:56:07 PM
smile   Problem using Ant, missing classes
Good evening,
I come to ask you a question once more, because I now have an issue building my application with Ant. The build is successful (I tried the jarExecutable and MacOsInstaller preselection with the good VM arguments) but when I launch my application all the functionnalities I added in two new files placed in com.eteks.sweethome3d.swing don't work. Nothing happens when I click on the button I added, when a new window should appear. I precise that appart from the part I added SweetHome is working well.
I checked and my classes are in build/classes. I don't understand why my functionnalities don't work, because Ant is set to pack "all workspace".
Thanks for your help smile ,
Mikaël
Posted by Puybaret at May 25, 2012, 9:04:33 AM
Re: Problem using Ant, missing classes
What exception stack trace do you get in /Applications/Utilities/Console program?
Posted by mikeycast at May 25, 2012, 11:05:53 AM
When I click on the button I added I get the error (I put what I found pertinent) :
.com.apple.JarLauncher: Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at com.eteks.sweethome3d.swing.ControllerAction.actionPerformed(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
Caused by: java.lang.NoClassDefFoundError: com/lowagie/text/Elementat com.eteks.sweethome3d.swing.MonitoringFrame.createSensorPagePanel(Unknown Source)
Caused by: java.lang.ClassNotFoundException: Class com.lowagie.text.Element
at com.eteks.sweethome3d.tools.ExtensionsClassLoader.findClass(Unknown Source)
Posted by Puybaret at May 25, 2012, 2:06:33 PM
com.lowagie is the package base of iText library.
Could you check the source code version you use?
Because I remember that I fixed in version 3.5 an issue about iText version that was wrong in SweetHome3DBootstrap.java.
Posted by mikeycast at May 26, 2012, 12:24:03 PM
Ok this fixes my issue, I just refreshed the file you cited. Now my window is lauching but I have some other issues :
- First, the "é,è,à" characters are not printed well, even though Ant is encoding in UTF-8...
- Secondly, I have a JPanel composed with JCheckBox which is absent sad
Can you continue to help me please? I don't have any error message in the console this time.
Posted by mikeycast at May 31, 2012, 8:10:45 PM
Hello,
an idea where it can come from? Of why my panel is not showed?
The panel is printed thanks to values from a distant database. Could it be a problem of connexion? Are the supplementary sql packages automatically added by Ant?
Thanks for your help,
Mikael
Posted by Puybaret at May 31, 2012, 10:04:46 PM
Without source code, it's impossible to be sure. You probably didn't pay enough attention to the encoding of the files that contain accented letters, and executed your plug-in on a different OS.
Posted by mikeycast at Jun 4, 2012, 12:20:48 AM
Thank you, and what do you think about the sql connection problem?
I've added mysql-connector-java-5.1.18-bin.jar to the libs but Ant may not include it.
Should normally Ant add the .jar I added in /lib or do I have to force it by modifying the build.xml file?
I think about this because the symptoms are the same than when I had some problems connecting to the database.
Anyway, I don't have any messages in the Console.
Posted by mikeycast at Jun 5, 2012, 7:03:52 PM
Hello, I've juste read the post from Mitsaki and so I've added my packages to the SweetHome3DBootstrap, in the extensionJarsAndDlls array. And thanks to your link I know now that my .jar are included during the building, while they are in /lib.
Still the connection to the database doesn't work and I don't have any messages in the console.
Do you have any ideas of other things to do to make it work?
Please, I have 3 days left to fix it until my presentation...
Posted by Puybaret at Jun 5, 2012, 8:50:45 PM
You may have to add the packages of your project in applicationPackages of SweetHome3DBootstrap too.
If you have nothing in the console, run in a Terminal window your JAR executable file with command:
java -jar jarExecutableFile.jar
Without source code or a stack trace it will be difficult to help you further. I just can't guess what is wrong. I don't even know why you use a database and how!!!
