Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Doors not punching holes |
| Print at Oct 5, 2026, 11:20:31 PM | |
| Posted by Lynn22 at May 23, 2012, 3:46:12 PM |
Doors not punching holes Hi everybody, I'm new to the forum but not new to Sweet Home which I discovered several years ago and may I congratulate the developer since the program has really 'matured' over the years. Getting back into building interiors I've ran into a snag. I downloaded the models listed below but when I place them in my building - with magnetism turned on - they will only snap to the outside (inner or outer) of a wall. When I turn magnetism off then I can place them in the wall but they don't create the 'hole' they should fit in. Is there any setting that I am missing to make this work ? Many thanks for any help I can get Sliding French doors http://www.sweethome3d.com/models/contributions/frenchDoors.zip Darker front door http://www.sweethome3d.com/models/contributions/frontDoorDark.zip Door http://www.sweethome3d.com/models/contributions/door1.zip Exterior door http://www.sweethome3d.com/models/katorlegaz/exterior-door-07.zip |
| Posted by beber_mal at May 23, 2012, 5:02:33 PM |
Re: Doors not punching holes have you check the option "door or window" in the furniture import wizard? |
| Posted by Lynn22 at May 23, 2012, 7:23:28 PM |
Re: Doors not punching holes Thank you very much beber_mal that was the setting that I missed. All is working fine now |
Current timezone is GMT Oct 5, 2026, 11:20:31 PM |
