Print at Aug 16, 2026, 8:42:10 PM
Posts: 18   Pages: 2   [ 1 2 | Next Page ]
Posted by jibbyjibs at May 9, 2012, 10:11:50 PM
White Space Between Grass & Sky
Hey Guys & Girls. Hoping you can help with this one. I almost have my house design close to done, but can't figure out how to fill in that white space between the ground and the sky. When I do my video, I'd like to be able to show an outside view, but not with that white space there. Any tips and tricks would really be appreciated.
Posted by Puybaret at May 9, 2012, 11:28:26 PM
Re: White Space Between Grass & Sky
I really don't understand how this could happen in recent versions of Sweet Home 3D. What version do you use?
Posted by jibbyjibs at May 12, 2012, 7:10:35 AM
I'm using version 3.5 Java web start Java version 1.6.0_29. I made a 30 second (low quality) video to show what I'm talking about.
I don't think I can attach it here on this forum so have e-mailed it to you instead. When I take the view right down to the ground, it helps somewhat, but this isn't an angle I want to use.
An e-mail from TranquilityLodge in your inbox is from me.
I hope you can help!
Posted by Puybaret at May 12, 2012, 12:28:37 PM
The zone shown around the garden is white because you didn't change the ground color or texture in the 3D view modification dialog box.
Posted by jibbyjibs at May 12, 2012, 9:10:41 PM
Simple as that... :D Thank you so much, Emmanuel!! Problem is solved.
Posted by speed777777 at Sep 11, 2012, 8:38:40 PM
hi emmanuel i was using 3.5 java exec and now 3.6 java exec and still have this problem with the white line on the horison, even though 3d view ground texture has been set to grass and the other to sky. could this be the version i am using, or something else. cheers shaun.
Posted by Puybaret at Sep 11, 2012, 10:02:38 PM
How large is your home?
Posted by speed777777 at Sep 12, 2012, 7:38:51 AM
hi emmanuel all the houses i do are rather large over 500 megs, but under 1 gig. cheers shaun
Posted by speed777777 at Sep 17, 2012, 11:35:40 PM
hi emmanuel hope you well any ideas yet. cheers shaun
Posted by Puybaret at Sep 18, 2012, 1:46:49 AM
By "large", I didn't mean "file size" but "house size" (in a length unit) wink
