Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: change between levels |
| Print at Sep 20, 2026, 7:18:09 AM | |
| Posted by vertice at May 3, 2012, 1:46:41 PM |
change between levels i dont know how to change to the level 0 after create the level 1. i'm trying to do a "loft" with a not complete second floor (level 1), i dont know either if you can make the complete rail (?) at once. i'm spanish so i dont know if i explain myself as well as i'd like to. be well people! and thnx u |
| Posted by Puybaret at May 4, 2012, 2:18:46 AM |
Re: change between levels Sorry, I'm not sure to have completely understood what you meant. At each level you can draw some rooms which will cover the lower level, and if you want to draw some kind of mezzanine, just don't draw any room for the hole. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by vertice at May 4, 2012, 9:26:32 AM |
Re: change between levels Yes, i know that. What want to know is, once you add the next level (and make the rooms in that) how can i, for example, add some forniture to the level under the new one. Thanks |
| Posted by Puybaret at May 4, 2012, 10:35:10 AM |
Re: change between levels Select the level with the tabs shown at the top of the plan. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by vertice at May 4, 2012, 11:16:53 AM |
Re: change between levels Hahaha I´m so stupid sometimes. Thanks so much!! |
Current timezone is GMT Sep 20, 2026, 7:18:09 AM |
