Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: PLAN>Modify walls |
| Print at Sep 20, 2026, 2:42:37 AM | View all posts in this thread on one page |
| Posted by cicliced at Apr 28, 2012, 6:15:04 PM |
PLAN>Modify walls Hi, I have just started using this program and am getting on fine with it apart from there seems to be a few menu options greyed out on the menu, specifically 'PLAN>MODIFY WALLS', so i'm unable to edit the floor colour etc. Any ideas why this might be? Thanks James |
| Posted by hansmex at Apr 28, 2012, 7:18:36 PM |
Re: PLAN>Modify walls 1 - You have to select a wall, before you can modify it. 2 - To edit a floor, you first have to draw a room, then you can edit it with Modify room. Maybe it's a good idea to read the User's guide first? Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by cicliced at Apr 28, 2012, 7:54:18 PM |
Re: PLAN>Modify walls Hi Hans, Sorry I meant to say specifically 'MODIFY ROOMS' is greyed out in the menu, so I can't access it. I have created 1 room. The plan is unlocked. Thanks James |
| Posted by Puybaret at Apr 29, 2012, 1:12:28 AM |
Re: PLAN>Modify walls You have to select first the rooms you want to modify. If you want to change them, select all, it's not a problem if the selection contains other kinds of objects. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by cicliced at Apr 29, 2012, 2:44:03 PM |
Re: PLAN>Modify walls Hi Emmanuel, I have selected the rooms but it still doesn't let me have access to 'modify rooms'. See screen print below... [IMG]http://i50.tinypic.com/309pmra.jpg[/IMG] Am I selecting it correctly? Do all the walls have to be 'joined'? it looks like all the walls are joined apart from one wall that just overlaps at the corner and won't connect to the other wall. Thanks James |
| Posted by cicliced at Apr 29, 2012, 4:25:24 PM |
Re: PLAN>Modify walls Here is the link to the file i created if you want to have a look at it. https://docs.google.com/open?id=0B6ErAvoNHHrUZEVkSTltazZIRWc You have to click 'file'>'download' at the top left of the screen. |
| Posted by cicliced at Apr 29, 2012, 5:54:27 PM |
Re: PLAN>Modify walls i solved it, i didn't have the room corners set, i was just drawing on the initial screen that opened. |
Current timezone is GMT Sep 20, 2026, 2:42:37 AM |
