Print at Sep 6, 2026, 12:09:55 PM
Posted by leech at Mar 23, 2012, 6:20:25 PM
CopyAsNewFurniture
Hi all,
I installed the above plugin as explained in the tutorial. I'm using linux.
The plugin is loaded in SH3D. So far so good. If I then draw a wall and try to copy as new furniture, the paste symbol lights up and I can paste, but nothing happens. No error, no actual paste, nothing.
Am I doing something wrong?
I am using SH3D in version 3.4. 64bit Installer.
Posted by Puybaret at Mar 23, 2012, 7:00:18 PM
Re: CopyAsNewFurniture
Please launch the program from a Terminal window, and if some text starting by "Exception in thread" appears in the Terminal when Paste operation doesn't work, copy it in a message here. Be sure also that the plan or the furniture list have focus when you paste your copied item.
Posted by leech at Mar 23, 2012, 8:24:27 PM
Thanks for the quick reply.
I already tried several times opening form a terminal. There is just no output at all in the terminal.
No info, no Exception or anything.
Posted by hansmex at Mar 23, 2012, 9:40:28 PM
Please note that the copy is placed exactly on top of the original. Sometime it looks as if nothing happened but the copy is there.
Posted by leech at Mar 23, 2012, 10:33:02 PM
I know that the copy should be at the same position as the original. But as I said, nothing happens. I can move the original afterwards and nothing else is on the plan nor the 3d view.
Posted by hansmex at Mar 23, 2012, 11:06:15 PM
I use Ubuntu 10.10 without any problem.
I don't install plugins, I just copy them to the ./eteks/sweethome3d/plugins directory. That's all.
Posted by leech at Mar 23, 2012, 11:08:41 PM
I'm here on Gentoo 64bit. Will try to do a fress install and report back.
By the way, I also only copy the plugins.
Posted by hansmex at Mar 24, 2012, 1:26:03 AM
You may want to try sometyhing else.
Uninstall all Java from your computer (SunJava, IceTea,JDK, etc) and then re-install (unzip) SH3D.
That may resolve Java-conflicts and help you to get a clean SH3D installation.
Hans.
Posted by Puybaret at Mar 24, 2012, 2:01:15 AM
I don't believe Leech's issue is bound to Java or Sweet Home 3D install. There must be something else. If you want, you can send your faulty file to me and I'll have a look.
Posted by leech at Mar 25, 2012, 12:39:15 AM
After a completely new install I have to report, that it still won't work.
Here is what I am doing:
I open up SH3D and create a new file. After drawing a single wall, I select it and use CopyAsNewFurniture. The paste symbol lights up, but does nothing when clicked upon. After loosing focus of the plan, the paste symbol vanishes.
No output whatsoever on the terminal.
