Print at Jul 14, 2026, 6:24:09 PM
Posted by Nyks at Mar 5, 2012, 10:31:28 AM
How to save plan/layout as image (PNG)
Hi!
I want to use Sweet Home 3D, to draw plans (using german client, in english its called maybe something like grid/layout/2D/...).
Is there any easy buildin feature to save the layout as an image?
Posted by Puybaret at Mar 5, 2012, 11:06:59 AM
Re: How to save plan/layout as image (PNG)
You can select all the objects in plan then choose Edit > Copy menu item to copy them in the clipboard, then paste this image in any drawing software or in a word processing software (copy / paste may miserably not work under Linux).
You can also choose the Plan > Export to SVF format menu item, and convert the SVG file you'll get in a PNG with Inkscape or other software that supports SVG file format.
