Print at Sep 13, 2026, 10:33:02 PM View all posts in this thread on one page
Posted by linux4ever at Feb 6, 2012, 9:42:21 PM
My SweetHome3D house
Hey people,
I've been working on a house project in the past 6 months or so changing it, so it fits the future needs. It has most of the things a house has.
Main floor:
- main hallway
- 1 living
- 1 kitchen+eating area
- 2 bedrooms
- 3 closets
- 1 work area
- 2 bathrooms
- 1 cleaning closet
- 1 kitchen closet
- 1 washing area
- 1 car garage
- 1 small room for gas heating
Basement:
- main hallway
- 2 storage closets
- 1 spare room that can be a bedroom
- 2 other small rooms for work
- 1 storage basement
This is main level:
This is the basement:
I could not accomplish some things like making a triangular wall and some other things like cuts in the kitchen wall, but I put a door and scaled it, so it looks like the cut. Anyway, SeetHome3D has been a great software so far. Easy to use and free.
I would like more features implemented, so I can get the roof built and integrate the software into sattelite imagery, but these will probably come in the future.
Here is the sh3d file:
.SH3D file
Hope you like it!
Posted by Puybaret at Feb 6, 2012, 9:59:06 PM
Re: My SweetHome3D house
Thank you for sharing your nice project ! I'm happy to see that multi levels feature is useful for some of you. smile
Note that you can choose a negative elevation in the level modification panel.
Posted by linux4ever at Feb 6, 2012, 10:06:32 PM
I don't know to do a lot of things, but from my perspective, things are almost functional. I would still want to crate a triangular wall and an angle ceiling. Not sure if this can be easily implemented. And the roof thing of course. I've seen lots of people doing roofs here, but I have no clue how to do them... It's not very obvious.
The project is not perfect, but it makes things in real life do-able for sure. 5 years down the road, this house will become reality. I'm just stuck with some other things right now.
Posted by macfrog at Feb 19, 2012, 11:42:46 AM
linux4ever,
really impressive! Thanx for sharing your results!
For your wall cutout you can use the "invisible box". Angle ceiling is rather easy if you make sure not to "twist" the room, e.g. parallel sloping walls has to be the same.
For this and a lot more (like roofs) there is a tutorial to download. You might find it very useful i believe.
macfrog
Posted by linux4ever at Mar 17, 2012, 10:31:46 PM
Hi again,
I've been poking around with the roof thing and I also adjusted the hallways, modified the floor layout and so on... I am now able to get the roof on and the project is in final stage. You can check out the pics in this link:
http://www.blackpenguin.org/blog/post.php?idpost=13
I will give you a link to the updated SH3D file, but I just did not have the time to put it out there. Thanks!
Posted by linux4ever at Apr 28, 2012, 4:28:27 PM
Here's an updated version of the house. Elevated ceilings, modified hallways, adjusted basement, electrical outlets and plugs, roof, solar instalation and so on...
http://www.blackpenguin.org/final.sh3d
I think these would be the final touch-ups...unless the software upgrades, then I will put more in.
Posted by Puybaret at Apr 29, 2012, 1:27:02 PM
Very nice work! And a real example of a way to use levels as layers. smile
May I suggest you save your file with File > Save and compress menu item before sharing it, this would greatly reduce the size of the file to download.
Posted by linux4ever at Apr 29, 2012, 3:39:24 PM
I compressed it and relocated the file. And you're right - it reduced the size from 27MB to about 8MB...
Here's the compressed project:
http://www.blackpenguin.org/sweethome3d/final.sh3d
Posted by linux4ever at Apr 29, 2012, 3:41:20 PM
Anyway Emmanuel, you can use this file to share it as an example for SweetHome3D on the web site if you want... It might be useful for people to see bigger projects and play before they start their own. I might have mistakes here and there, but it's a good start to follow.
Thanks!
Posted by linux4ever at Jul 10, 2013, 12:09:20 AM
I updated the house plans to a new topic:
http://www.sweethome3d.com/support/forum/viewthread_thread,4262
As I mentioned before, Emmanuel, you can use the sh3d file in the new topic as an example if you want it. Thanks.
