Print at Sep 6, 2026, 2:34:02 PM View all posts in this thread on one page
Posted by krunchyfrog at Jan 28, 2012, 2:29:01 PM
merge many files in one?
Hello,
Before version 3.4 I simply did a few files for the different floors of my house and the future extension of it. Is there a way to merge them all together now? It's basically 3 files: the original first floor that is about 4ft above ground, the garage, at ground level, and the second floor that will cover the two first file's widths together. I hoped simply copy and pasting would suffice, but no go.
Thanks
K
Posted by hansmex at Jan 28, 2012, 3:03:53 PM
Re: merge many files in one?
Yes, you can do that. It's a simple Copy & Paste action.
1 - Open a target file where all floors will be combined
2 - Use Plan --> Add level to make as many levels as needed.
3 - Open your first source file and select everything with CTRL-A, then copy it with CTRL-C
4 - Switch to your target file, select the correct level and paste everything with CTRL-V
5 - Repeat step 3 and 4 for the other files/floors.
Posted by krunchyfrog at Jan 28, 2012, 3:45:22 PM
thanks! didn`t try ctrl-a, I simply tried selection and that wasnt working.
I noticed however that a few furnitures didn`t take the import correctly, like a few werent in the right height (computer hanging in thin air for example) and others had lost their textures. But thats ok, I was about to redo a few of them anyway ;)
Posted by Kytrix at Feb 3, 2012, 7:27:23 PM
Hello,
I am aslo using the Copy/Paste tips to merge many files, but how to do rotate one whole plan ?
(I try Ctrl+A then group then rotate, but the base plan is not rotated :/ )
I also try with différent compas, but it doesn't work too.
Posted by hansmex at Feb 3, 2012, 8:15:09 PM
Download the plug-in tutorial (PDF).
Install and use the RotatePlan plug-in.
Posted by Kytrix at Feb 3, 2012, 9:07:47 PM
Thank you !
It works well :)
