Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Selecting multiple elements |
| Print at Oct 5, 2026, 9:43:55 PM | View all posts in this thread on one page |
| Posted by coldcomfort at Jan 7, 2012, 2:02:59 PM |
Selecting multiple elements Would be practical if we could select multiple elements (walls) with ctrl+click, then copy/cut/drag or edit(?) them all at once. Of course, when pasting them, all the original relations should remain. I know this is kind of possible now. But only by using the rectangular selection field, which isn't a flexible option (since we can't unselect discriminately). Also, when selecting multiple elements, would be useful if the angle between adjacent walls would show up... |
| Posted by Puybaret at Jan 7, 2012, 2:55:20 PM |
Re: Selecting multiple elements As indicated in the help about walls modification, use with the shift key to select other walls then choose the Modify walls menu item in the Plan menu. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by coldcomfort at Jan 7, 2012, 4:17:04 PM |
Re: Selecting multiple elements Thank you. Seems I should read much more, before I open my mouth again Or maybe it's your fault for thinking at/implementing everything that's necessary already. |
| Posted by Puybaret at Jan 7, 2012, 5:03:28 PM |
Re: Selecting multiple elements Or maybe it's your fault for thinking at/implementing everything that's necessary already Next time someone requests a feature I don't feel like implementing, I'll use the excuse "Sorry I must keep a few features out of Sweet Home 3D, otherwise we won't have anything to discuss about!"---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 5, 2026, 9:43:55 PM |
