Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D view won't select upper level |
| Print at Sep 6, 2026, 6:24:09 AM | |
| Posted by Gibbo at Dec 31, 2011, 12:34:31 AM |
3D view won't select upper level Hello to all I am a new user working on a PC with Windows XP. I have built a (minimum) 2 level model of my house, but am having problems with the 3d view. The aerial view is fine and I can run the virtual visitor view of the ground floor, but I can't get the virtual visitor view of the upper floor. When I select display selected level on the ground floor, it works correctly and the aerial view only shows the ground floor. However, when I do the same for the top floor the whole house is still displayed and the visitor refuses to go upstairs! I have been through all the existing posts, the user guide and the FAQs, but found nothing of help. Can anyone help? |
| Posted by hansmex at Dec 31, 2011, 12:59:47 AM |
Re: 3D view won't select upper level John, To view the upper level(s) of your design, right-click in the 3D preview window and select Display all levels; this will show all levels at the same time. If you want to see the topmost level, right-click in the 3D preview window and select Display selected level; this will display the level that is activated with the Level tabs above the 2D window, and all levels below that level. So if you have 3 levels and want to see the lower 2 levels, select Level 2. If you want to see all three levels, select Level 3. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Gibbo at Dec 31, 2011, 1:18:35 AM |
Re:
3D view won't select upper level Thank-you, this has solved half the problem, as I didn't expext selected level to show all levels up to the selected level. I have now managed to view upstairs by modifying the eye-level in the 3D modify options to a suitable height. Is this the only way to move the visitor between floors, or am I missing something? Getting there slowly! John |
| Posted by hansmex at Dec 31, 2011, 4:15:51 AM |
Re: 3D view won't select upper level John, Yes, and no. Yes, it's the only way to move the virtual visitor around. No, because after selecting a view position, you can store it using 3D view -> Store point of view. With 3D view -> Go to point of view you can then revisit your view points by selecting one of the view points from the list. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Dec 31, 2011, 10:02:03 AM |
Re: 3D view won't select upper level What about using the eyes elevation indicator available in the back of the virtual visitor in the 2D plan? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Gibbo at Jan 1, 2012, 1:57:05 PM |
Re: 3D view won't select upper level Thanks to all. I am up and running now. John |
Current timezone is GMT Sep 6, 2026, 6:24:09 AM |
