Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: adding a lower level after a higher one? |
| Print at Sep 6, 2026, 5:51:37 AM | View all posts in this thread on one page |
| Posted by coldcomfort at Dec 22, 2011, 1:38:38 PM |
adding a lower level after a higher one? Hey there. I was trying the new version (3.4) and I noticed an inconvenience, or maybe I just don't know how to use it right. When adding new levels, the new one always build on top of the previous. This wouldn't be a problem if we could rearrange the order... ...What I mean is, after I built a large level, I figure out i need another one (much smaller) at a lower height, but unless i delete it, i cant go lower. If only we could move (rearrange) the level tabs, or set absolute heights instead of relative to the previous level, then it would be perfect. |
| Posted by Puybaret at Dec 22, 2011, 1:55:01 PM |
Re: adding a lower level after a higher one? Before the user's guide get updated, please read the integrated help about levels, available in English also here and here. It gives the answer to your questions. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by coldcomfort at Dec 22, 2011, 2:19:14 PM |
Re: adding a lower level after a higher one? Oh yes, sorry. There's a "modify level" menu with the elevation value, a simple and elegant solution (allowing both to rearrange tabs and set absolute height values). |
Current timezone is GMT Sep 6, 2026, 5:51:37 AM |
