Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Ceiling missing |
| Print at Oct 1, 2026, 12:06:13 AM | |
| Posted by Jokus at Nov 21, 2011, 5:32:07 PM |
Ceiling missing Moin! In meinem Zimmer gibt es zwei Dachschrägen:Modell Leider wird so die Decke nicht angezeigt, bzw nur teilweise: nur auf höhe der tiefsten Wand. Dazu läuft ein Teil der richtigen Decke mitten durch den Raum (Fehler?!) Wie kann ich das beheben? --- Hello! In my model are two droops. If I want to see the ceiling, there is just the ceiling on the height of the smallest wall (in this case 77 cm). Additionnal there is a part of the ceiling across the romm (bug?!). How may I change this? Viele Grüße Malte |
| Posted by hansmex at Nov 21, 2011, 6:05:22 PM |
Re: Ceiling missing Malte, You should make two "rooms" in your room. One room for the horizontal ceiling, one room for the sloping ceiling. Have a look at the roofs tutorial (PDF in english). Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Jokus at Nov 21, 2011, 6:58:24 PM |
Re: Ceiling missing Thank you ;) Works perfekt! |
Current timezone is GMT Oct 1, 2026, 12:06:13 AM |
