Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Bay Window |
| Print at Sep 20, 2026, 12:39:35 AM | View all posts in this thread on one page |
| Posted by fanyam at Nov 21, 2011, 5:00:03 PM |
Bay Window Could you please tell me where I can find 3D Bay Window with 90 degrees, sort of like a box window outside the wall. I could not find on the web... :( Thanks |
| Posted by hansmex at Nov 21, 2011, 6:07:08 PM |
Re: Bay Window Did you look in the Sketchup Warehouse? The search term "bay window" gives a lot of results... Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by fanyam at Nov 22, 2011, 1:16:37 PM |
Re: Bay Window Yes, I did. But I could not find the one angled back 90 degrees |
| Posted by hansmex at Nov 22, 2011, 1:46:19 PM |
Re: Bay Window Can you show a picture of what you are looking for? ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by fanyam at Nov 24, 2011, 2:35:35 AM |
Re: Bay Window Hi Hans, I have uploaded a picture to below : http://sourceforge.net/tracker/?func=detail&a...id=152568&atid=784668 thanks |
| Posted by hansmex at Nov 24, 2011, 10:07:29 AM |
Re: Bay Window This is more a room extension than a bay window, in my view. So, I would treat it as one by drawing walls and inserting windows. That way you can have a floor and ceiling as well. Note that you can stack two windows on top of each other, if the window configuration should closely match your picture. Hans bay window.sh3d ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by fanyam at Nov 26, 2011, 5:23:38 AM |
Re: Bay Window I'm not sure if it could work as I need to rise in floor level and lower the ceiling height in the window area in order to match the actual status. Let me try and update you later. Thx so much Hans. fanyam |
| Posted by hansmex at Nov 26, 2011, 10:48:10 AM |
Re: Bay Window Fanyam, There's a solution for everything. 1 - Use SH3D version 3.3 with the CopyAsNewFurniture plug-in installed. 2 - Design your "bay window" 3 - Use boxes for floor and ceiling 4 - Use CopyAsNewFurniture and then Export to OBJ format to export your window as a model. 5 - Use Import furniture to use your model. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 12:39:35 AM |
