Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Import .obj file to Blender |
| Print at Sep 19, 2026, 3:38:11 PM |
| Posted by Ferraro at Oct 24, 2014, 11:03:27 PM |
Re: Import .obj file to Blender I have been looking into this as well. Ideally OBJ groups should be created by individual pieces of furniture. The OBJ writer appears to write g + objectName and then falls back to the nodeName. g being the obj files designation for group. Could it be that the nodeName being used for all furniture is simply "mesh" Line 344 of OBJWriter.java mentions a unique name that is "human readable". Ideally the furniture library name should be inserted here. However, on closer examination of the output file it appears it only writes groups by the textures used. As a workaround, I am thinking perhaps I should build my models with a single image texture map from now on. Any thoughts on an implementation that passes the furniture library name as nodeName? |
| Posted by unitedwewillwin at Dec 24, 2021, 4:45:09 PM |
Re: Import .obj file to Blender I was facing the same issue and found a great, efficient way to separate objects in Blender (only takes a few seconds!) To do that, just select the imported object in Blender, go into Edit Mode (pressing the "tab" hotkey on your keyboard), then press "P" on your keyboard. A small tab opens and you can choose to separate the items either by Material or by Loose Parts. Here is the Youtube tutorial I found that explains it: https://www.youtube.com/watch?v=P_C3xkVT044 The only downside is that in the Blender Outliner, the different parts don't take the name they had in Sweet Home 3D. For example "Table" is called "ProjectName.001", but this can be manually changed. Hope this helped! |
Current timezone is GMT Sep 19, 2026, 3:38:11 PM |
