Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: wall edge |
| Print at Sep 6, 2026, 5:56:57 AM | View all posts in this thread on one page |
| Posted by walterschmitz at Oct 30, 2011, 7:11:04 AM |
wall edge Hello, i create a wall and i finished the wall at a point. if i want to create a new wall, which starts at this edge / point, i will not be able to connect both wall in this way, that i seems like ONE wall. there is always a shift, if i see the wall on 2d paper print. maybe i'm to studid, to see some connection-point, but is it able to connect two walls, if i have to create a wall later? Thank you for helping |
| Posted by hansmex at Oct 30, 2011, 8:43:29 AM |
Re: wall edge Walter, If you install the AdvancedEdit plug-in, you will find there is a function called Connect Walls. Please, read the tutorial on plug-ins (PDF) to learn how to install the plug-in and how to use it. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Oct 30, 2011, 10:28:55 AM |
Re: wall edge You could try also the version 3.4 beta where magnetism during wall drawing was improved. If you click on the end point of a previously created wall, the start point of the new wall will be exactly at that point whatever the scale factor you used in the plan. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Onkelka at Jan 31, 2012, 5:42:13 PM |
Re: wall edge Hans, after installing the "AdvancedEdit" plug-in I'm not able to find "Connect Walls" under "Plan". Christian |
| Posted by hansmex at Jan 31, 2012, 6:00:53 PM |
Re: wall edge Christian, If you have installed the plug-in correctly, the plug-in most definitely should be there. If you have downloaded the plug-in tutorial (PDF), check that the plug-in is copied into the correct directory for your operating system. Then re-start SH3D to activate the plug-in. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Psuitsi at Feb 1, 2012, 7:49:51 AM |
Re: wall edge Well, I also have trouble with some plugins ( http://www.sweethome3d.com/support/forum/viewthread_thread,2877 ). They just won't show up in SH3D (in 2 laptops, one with Win7 and the other with XP), even if they are, supposedly, installed "correctly". Still think it's a bug... |
| Posted by lalberts at Aug 21, 2016, 1:29:55 PM |
Re: wall edge Hello, I followed the instructions but: Where do I find this connect-walls? Lukas |
| Posted by okh at Aug 22, 2016, 12:47:36 PM |
Re: wall edge Where do I find this connect-walls? Normally drop-down menu Plan, at the bottom. Remember to set the walls in the 'same' direction (use Reverse walls direction if the walls run in 'opposite' directions) and select the two walls to be connected in correct sequence first. ok |
| Posted by Miker777 at Aug 23, 2016, 12:28:37 AM |
Re: wall edge Hiya You may like to try viewing a video on you tube demonstrating the connection of walls, hopefully it will help. Walls Mike ![]() |
Current timezone is GMT Sep 6, 2026, 5:56:57 AM |
