Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Add picture on 2D panel only |
| Print at Sep 13, 2026, 4:22:39 PM | |
| Posted by dlarroumets at Sep 8, 2011, 3:54:12 PM |
Add picture on 2D panel only Hi, Is it possible to add little pictures in 2D panel only ? Like a furniture from a library by drag and drop ? Thanks |
| Posted by Puybaret at Sep 8, 2011, 4:55:11 PM |
Re: Add picture on 2D panel only If you want to add pictures in the 2D plan only, you should create a separated .sh3f furniture file that will contain these pictures, an invisible OBJ file and a PluginFurnitureCatalog.properties file that will describe the fake catalog furniture you want to describe. As the Furniture Library Editor is not designed to manage invisible models with a visible icon, you won't be able to use (or you'll have to edit the generated file afterwards). To show you how to proceed, I attached the Symbols.sh3f demo file that describes an information symbol and a phone symbol. Each symbol is described with some properties listed in DefaultFurnitureCatalog class followed by # and a order counter. name, category, icon, model, width, depth, height, movable and doorOrWindow are mandatory, whereas the other properties are optional. In your case, even if height isn't used, you shouldn't set it to 0. id is useful to avoid duplicates in case the same model appears more than once in different .sh3f files. deformable is interesting if you don't want to let the user change proportions. You should also define the planIcon property to ensure you use the correct icon, when furniture icons in plan should be rendered with top view icons and not catalog icons. # PluginFurnitureCatalog.propertiesIf you need, you can translate the name and category properties in files suffixed with country code, like in the following PluginFurnitureCatalog_fr.properties French file (encoded with ISO_8859_1): # PluginFurnitureCatalog_fr.propertiesI hope you can handle this workaround. Of course it isn't perfect since some attributes in furniture dialog become completely useless in that case. I may add a new property in properties files to handle this case in a future version. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by dlarroumets at Sep 8, 2011, 5:51:20 PM |
Re: Add picture on 2D panel only I tested your files, and it looks perfect for me. Note for newbie : use the menu "Import library furniture" and not right click import on treeview... Thanks a lot Emmanuel |
| Posted by dlarroumets at Sep 8, 2011, 5:55:06 PM |
Re: Add picture on 2D panel only Note 2 : sh3f is a zip file. |
| Posted by Puybaret at Sep 8, 2011, 8:06:51 PM |
Re: Add picture on 2D panel only Great you like it! sh3f is a zip file Thank you for mentioning this important detail.An other important thing: I published in public domain the invisibleCube.obj OBJ file contained in the attached .sh3f file to let anyone use it with no limitation. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by skliarie at Jan 22, 2014, 11:55:09 AM |
Re: Add picture on 2D panel only I took the symbols library, added more symbols (electric socket, high-powered socket, lamp and reserved) and published it over here: http://arnest.catchmedia.com/tmp/electrical.sh3f My only concern is that the electric socket symbol should be rotateable (the protruding stick should look in the opposite side from the wall). What should I add to the properties files for that? |
| Posted by skliarie at Jan 31, 2014, 9:53:37 AM |
Re: Add picture on 2D panel only I added to the symbols library more elements (two poles switch, with and without lamp, looking in different directions) - on the same URL (see above). Is there a way to remove black border around the elements? It seems to be automatically added by sweethome3D. Any idea about automatically rotating the icons depending on the base? Currently I am forced to provide 4 different icons for each direction.. |
| Posted by Puybaret at Jan 31, 2014, 11:39:37 AM |
Re: Add picture on 2D panel only Is there a way to remove black border around the elements? It seems to be automatically added by sweethome3D. No, and there won't. This rectangle is used to show the user in which zone he can click to select an object, but it's not printed or exported to PDF / SVG.Any idea about automatically rotating the icons depending on the base? I don't understand what you want. Why don't you use the rotate indicator available on each object?---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by skliarie at Feb 1, 2014, 9:23:52 PM |
Re: Add picture on 2D panel only The black border *is* exported in SVG export mode. Just import my furniture library, put couple of symbols and export to SVG. If I use rotate indicator - the pictogram remains in its original form and not rotated. I guess this also explains why autorotation (when the symbol "sticks" to the wall near it) does not work. I think the problem is in the way the symbols are described in PluginFurnitureCatalog.properties. |
| Posted by Puybaret at Feb 2, 2014, 12:23:48 AM |
Re: Add picture on 2D panel only Selecting Top view option for Furniture icons in plan in preferences will fix your two issues. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by dorin at Apr 25, 2014, 11:25:55 AM |
Re: Add picture on 2D panel only I've made a library with some usual signs needed in emergency plans. I start from Emmanuel sample and I intend to grow the items. Hope this help: 2D Symbols ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by FransW at Feb 25, 2015, 7:51:46 PM |
Re: Add picture on 2D panel only Hello to Skliarie Thanks a lot I realy use your Symbol electrical libery with pleasure. But how did you make them. with what program. I would love to make some myself. I am an electrician in France You must know I am new on Sweet Home and not a good technician , but very willing to try. I think your libery should be known more by other people Thanks |
| Posted by okh at Feb 26, 2015, 11:02:43 AM |
Re: Add picture on 2D panel only I agree that having standard electrical symbols wold be very useful. As I am not an electrician, I need to look for these symbols when I need them (and remain confused...), for instance at Commons Wikimedia Electrical symbols. To create the symbols themselves, you will need a graphics editor (Paint or similar will do, but a more advanced editor like the Gimp or Inkscape will let you do more). You probably will want to save the symbols in .PNG format. Then, you will need the Furniture Library Editor and edit the properties manually as described above and include the symbol file you created. Admittedly, this is not a very easy process, but it would be useful if someone expanded the library. Some symbols are also posted in SF 3D models 325. ok ![]() |
Current timezone is GMT Sep 13, 2026, 4:22:39 PM |
