Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Background Image from command line |
| Print at Sep 19, 2026, 5:54:43 PM | |
| Posted by kerfmas4 at Aug 26, 2011, 4:51:55 PM |
Background Image from command line Hello all. I would like to know if there is any way of execute a command to set the background image. Or command line. I normally work with c# and before starting learning java, wanted to know if its possible to connect some simple functions like preferences,background image with c#. Or if its possible to do programming a plugin. The views preferences are easy to solve due to we can save a sh3d file and load through an external program renaming it. So, what do you think will be more easy for me. For the future I would like to integrate a little window sh3d viewer with move, zoom, just this. A form control would be perfect. Thanks. |
| Posted by kerfmas4 at Aug 31, 2011, 3:36:18 AM |
Re: Background Image from command line OK. Finally I've decided to learn more about java. Now I can set a predefined Jpg as backgroundimage from the menu bar. My new question is: How could I autoload this plugin function when the application starts without clicking on the menu item? Thanks in advance. |
| Posted by Puybaret at Aug 31, 2011, 9:35:11 AM |
Re: Background Image from command line Welcome to Sweet Home 3D developer world. How could I autoload this plugin function when the application starts without clicking on the menu item? If you want to program this only from the plugin you already created, you could set the background image of the current home in the getActions method you programmed. I guess this is not very clean, but it seems like a init method is missing in the Plugin class.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kerfmas4 at Aug 31, 2011, 11:19:47 PM |
Re: Background Image from command line First of all, thanks a lot for your help. Now the code result that worked. package com.eteks.test;Thanks again. [Note from moderator: fixed code format] |
| Posted by Puybaret at Aug 31, 2011, 11:39:32 PM |
Re: Background Image from command line Great you succeeded! I fixed the code format otherwise it was unreadable. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 19, 2026, 5:54:43 PM |
