Print at Sep 19, 2026, 6:09:24 PM
Posted by Mitsaki at Aug 19, 2011, 4:24:41 PM
sad   How to run a new class in SH3D source
Hello again,
I have started programming and I created a new package in the existing SH3D source code. In this new package I have created a class that is used to create a new Home, with walls and furniture. When I run this class, the interface of SH3D is opened but nothing is created. (I run this class using the instructions of README.txt and having as a main class com.eteks.sweethome3d.SweetHome3D).
Could you tell me what I am doing wrong??
PS. My code seems to have no mistakes.
Mitsaki sad
Posted by Puybaret at Aug 19, 2011, 10:18:39 PM
Re: How to run a new class in SH3D source
Sorry, but with no source code, it's just impossible to help you!!! sad
Posted by Mitsaki at Aug 20, 2011, 9:38:49 AM
package Blender;
* Read_File_and_Save.java Aug 11, 2011
* Creation of a class that reads a text file and saves it in an array
* Afterwards, it creates a SH3D project which is according to user's preferences.
* @author Dimitra Micha
import java.beans.PropertyChangeEvent;
import java.beans.PropertyChangeListener;
import java.io.BufferedReader;
import java.io.DataInputStream;
import java.io.FileInputStream;
import java.io.InputStreamReader;
import java.util.ArrayList;
import java.util.List;
//import com.eteks.sweethome3d.io.DefaultUserPreferences;
import com.eteks.sweethome3d.model.CollectionEvent;
import com.eteks.sweethome3d.model.CollectionListener;
import com.eteks.sweethome3d.model.Home;
import com.eteks.sweethome3d.model.Room;
import com.eteks.sweethome3d.model.TextureImage;
//import com.eteks.sweethome3d.model.UserPreferences;
import com.eteks.sweethome3d.model.Wall;
public class FileRead {
/** Basic external class used to create a room and import furniture in it according to user's preferences.
* @throws Exception
public static void main(String args[])
// Maximum elements of the array:108 (200 obligatory, 88 optional)
String[] str = new String[108];
try {
// Open the file that is the first
// command line parameter
FileInputStream fstream = new FileInputStream("/Users/dimitramicha/Desktop/SweetHome3D1.txt");
// Get the object of DataInputStream
DataInputStream in = new DataInputStream(fstream);
BufferedReader br = new BufferedReader(new InputStreamReader(in));
String strLine;
//Read File Line By Line
int i=0;
while ((strLine = br.readLine()) != null)
// Print the content on the console
//System.out.println (strLine);
//System.out.println(i);
str = strLine;
System.out.println(str);
i++;
// Check each line - Don't forget to make them comments afterwards!!!!!
//Close the input stream
in.close();
catch (Exception e)
//Catch exception if any
System.err.println("Error: " + e.getMessage());
String Shape_of_Room = str[2];
String Shiny_Matt = str[3];
String Right_Wall_Color = str[5];
String Right_Wall_Texture = str[6];
String Left_Wall_Color = str[7];
String Left_Wall_Texture = str[8];
String North_Wall_Color = str[9];
String North_Wall_Texture = str[10];
String South_Wall_Color = str[11];
String South_Wall_Texture = str[12];
String Ceiling_Display = str[13];
String Ceiling_Texture = str[14];
String Floor_Display = str[15];
String Floor_Texture = str[16];
// Save in another array the list of furniture. The maximum of this list is 91
// (108 values in total - 17 already mentioned above)
int j;
for (j=0;j<91;j++) {
String List_of_Furniture = (String) str[j+17];
//Check the Shape_of_Room
//Else - If Statement
if (Shape_of_Room == "Parallelogram") {
// Create a home and a wall listener that updates lists when notified
Home Parallelogram = new Home();
final List<Wall> addedWalls = new ArrayList<Wall>();
final List<Wall> deletedWalls = new ArrayList<Wall>();
final List<Wall> updatedWalls = new ArrayList<Wall>();
final PropertyChangeListener wallChangeListener = new PropertyChangeListener() {
public void propertyChange(PropertyChangeEvent ev) {
updatedWalls.add((Wall)ev.getSource());
Parallelogram.addWallsListener(new CollectionListener<Wall> () {
public void collectionChanged(CollectionEvent<Wall> ev) {
switch (ev.getType()) {
case ADD :
addedWalls.add(ev.getItem());
ev.getItem().addPropertyChangeListener(wallChangeListener);
break;
case DELETE :
deletedWalls.add(ev.getItem());
ev.getItem().removePropertyChangeListener(wallChangeListener);
break;
//Create a Room
Room Parallelogram_Room = new Room(null);
Parallelogram_Room.addPoint(0, 0);
Parallelogram_Room.addPoint(0, 400);
Parallelogram_Room.addPoint(625, 400);
Parallelogram.addRoom(Parallelogram_Room);
//Creation Walls
Wall Left_Wall = new Wall(0, 0, 0, 400, (float) 7.62);
Wall North_Wall = new Wall(0, 400, 625, 400, (float) 7.62);
Wall Right_Wall = new Wall(625, 400, 625 ,0 , (float) 7.62);
Wall South_Wall = new Wall(625, 0, 0, 0, (float) 7.62);
// Add them to home
Parallelogram.addWall(Left_Wall);
Parallelogram.addWall(North_Wall);
Parallelogram.addWall(Right_Wall);
Parallelogram.addWall(South_Wall);
// Set as User Preferences the default User Preferences
//UserPreferences preferences = new DefaultUserPreferences();
// Set as Texture image the first texture that is available
//TextureImage firstTexture = preferences.getTexturesCatalog().getCategories().get(0).getTexture(0);
// Join end point of one wall to start point of the other wall (4 times - 4 walls)
Left_Wall.setWallAtEnd(North_Wall);
North_Wall.setWallAtEnd(Right_Wall);
Right_Wall.setWallAtEnd(South_Wall);
South_Wall.setWallAtEnd(Left_Wall);
if (Floor_Display == "true") {
Parallelogram_Room.setFloorVisible(true);
if (Shiny_Matt == "Matt") {
Left_Wall.setRightSideShininess(0);
North_Wall.setRightSideShininess(0);
Right_Wall.setRightSideShininess(0);
South_Wall.setRightSideShininess(0);
else if (Shiny_Matt == "Shiny") {
Left_Wall.setRightSideShininess(1);
North_Wall.setRightSideShininess(1);
Right_Wall.setRightSideShininess(1);
South_Wall.setRightSideShininess(1);
// http://cloford.com/resources/colours/500col.htm Color(int rgb)
// Create a string array which will be used to check the color of each wall
// Create an array of integers which includes the rgb numbers of the colors
String[] color = {"Grey","White","Red","Green","Yellow","Blue"};
int[] rgb = {13882323,16119285,6974207,10210715,9170175,15641692};
int k;
for(k=0;k<6;k++)
if (Left_Wall_Color == color[k]) {
Left_Wall.setRightSideColor(rgb[k]);
if (North_Wall_Color == color[k]) {
North_Wall.setRightSideColor(rgb[k]);
if (Right_Wall_Color == color[k]) {
Right_Wall.setRightSideColor(rgb[k]);
if (South_Wall_Color == color[k]) {
South_Wall.setRightSideColor(rgb[k]);
(it continues with the same code, else -if state but different objects are created)
Posted by Mitsaki at Aug 20, 2011, 7:03:31 PM
Where should I copy paste this code...
It seems not to work at all.
Posted by Puybaret at Aug 21, 2011, 12:44:35 PM
Ok, I think I understood what you want to do now.
If you want to display a home built by program from a derived version of Sweet Home 3D, you should:
- create a subclass of com.eteks.sweethome3d.SweetHome3D application class,
- add a main method that will instantiate and init the application from the arguments
- override the createHome method to return a com.eteks.sweethome3d.model.Home instance initialized the way you want.
Here's a base example:
import com.eteks.sweethome3d.SweetHome3D;
public class Test extends SweetHome3D {
public static void main(String [] args) {
new Test().init(args);
@Override
public Home createHome() {
Home home = super.createHome();
// Modify home as you wish here
return home;
Hope this will help you to start. smile
Posted by Mitsaki at Aug 21, 2011, 1:06:09 PM
Is there any change that I should write this into my code?
SweetHome3D Home3D = new SweetHome3D();
Home3D.addHome(Parallelogram);
Although, it still doesn't work...
Posted by Mitsaki at Aug 21, 2011, 1:07:41 PM
Sorry, I didn't see your reply:)))
I hope it works!!!
Posted by Mitsaki at Aug 21, 2011, 7:37:24 PM
confused   Re: How to run a new class in SH3D source
The thing is that I was expecting to have something created, a wall, a room...
but nothing is displayed.
Here is the code, after the changes.
package com.eteks.sweethome3d;
public class Blender extends SweetHome3D {
public static String[] str = new String[108];
public static String Shape_of_Room = str[2];
public static String Shiny_Matt = str[3];
public static String Right_Wall_Color = str[5];
public static String Right_Wall_Texture = str[6];
public static String Left_Wall_Color = str[7];
public static String Left_Wall_Texture = str[8];
public static String North_Wall_Color = str[9];
public static String North_Wall_Texture = str[10];
public static String South_Wall_Color = str[11];
public static String South_Wall_Texture = str[12];
public static String Ceiling_Display = str[13];
public static String Ceiling_Texture = str[14];
public static String Floor_Display = str[15];
public static String Floor_Texture = str[16];
public static String[] List_of_Furniture;
// First save the furniture in an array
// Maximum elements of the array:108 (91 obligatory, 88 optional)
int j;
// Declare the size of the List_of_Furniture
List_of_Furniture = new String[92];
List_of_Furniture[j] = str[j+17];
try {
String strLine;
// Read File Line By Line
int i=0;
str = strLine;
i++;
// Close the input stream
in.close();
catch (Exception e)
// Catch exception if any
// Run the application SweetHome3D and run method createHome()
Blender blender = new Blender();
blender.init(args);
blender.createHome();
// The ability of a subclass to override a method allows a class to inherit from
// a superclass whose behavior is "close enough" and then to modify behavior as needed.
// The overriding method has the same name, number and type of parameters, and return type
// as the method it overrides. An overriding method can also return a subtype of the type
// returned by the overridden method.
@Override
if (Shape_of_Room=="Parallelogram")
// Create a Room - Room (float[][] points)
// Any of these numbers can be followed by "F" (or "f")
// to make it a float instead of the default double
float[][] points = {{0f,0f},{0f,400f},{625f,400f},{625f,400f},{625f,0f},{0f,0f}};
Room Parallelogram_Room = new Room(points);
Parallelogram_Room.setAreaVisible(true);
// Add new Room to Home
// Notify Listeners
case ADD :
break;
case DELETE :
break;
//Creation Walls
// Add them to home
if (Shape_of_Room == "Square") {
Home Square = new Home();
if (Shape_of_Room == "Trapeze-1") {
Home Trapeze_1 = new Home();
if (Shape_of_Room == "Trapeze-2") {
Home Trapeze_2 = new Home();
return home;
Posted by Puybaret at Aug 21, 2011, 8:10:04 PM
You shouldn't call blender.createHome(); directly and your createHome method doesn't return the home to which you added all your walls!
Instantiate only once the Home class with super.createHome(); call and add the walls to this instance.
Posted by Mitsaki at Aug 22, 2011, 12:41:54 AM
Well, I corrected my mistakes and I call the method with what you suggested:
new Blender().init(args);
but I don't see any results in the interface
Posted by Puybaret at Aug 22, 2011, 10:18:47 AM
I'm sure about the piece of code I gave you.
Learn how to run Eclipse debugger, it will help you to understand how init and createHome work and check the logic of your program.
Posted by Mitsaki at Aug 22, 2011, 12:13:30 PM
okey:) Thanks for the advice:)
Posted by Mitsaki at Aug 22, 2011, 4:11:58 PM
The thing that worries me is that if I put
System.out.println("method called");
in the method, this message is displayed twice.
Posted by Mitsaki at Aug 22, 2011, 5:15:58 PM
BTW, it works now:)) Thanks a lot and sorry for the trouble.
Posted by Puybaret at Aug 22, 2011, 7:32:13 PM
Great you were able to find your problem! smile
