Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: second execute crashes the program |
| Print at Sep 6, 2026, 10:15:56 AM | |
| Posted by jrios at Aug 19, 2011, 12:00:26 PM |
second execute crashes the program Hello I use Linux Mint Julia with this kernel 2.6.38-3.dmz.1-liquorix-686. I have got this VGA card in the laptop 00:02.0 VGA compatible controller: Intel Corporation 82852/855GM Integrated Graphics Device (rev 02) The first time I download http://www.sweethome3d.com/SweetHome3D.jnlp and I execute this file. Then it is works. The program opens and runs well. I close the programa and I execute again http://www.sweethome3d.com/SweetHome3D.jnlp The program opens but crash and close it. I execute javaws -viewer and I see that the app is installed. I drop the apps and clean the cache, then when I execute SweetHome3D.jnlp again runs well Any ideas? |
| Posted by Puybaret at Aug 19, 2011, 10:21:25 PM |
Re: second execute crashes the program Quite a strange behavior! You probably have two Java virtual machines installed on your system. Unless you perfectly know how to handle this, I would give a try to the installer version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jrios at Aug 20, 2011, 11:03:54 AM |
Re: second execute crashes the program Quite a strange behavior! You probably have two Java virtual machines installed on your system. Unless you perfectly know how to handle this, I would give a try to the installer version. Hello, I have download this link, unzip and execute and I have the same result. Opens the program and closes itself. With this version I drop the apps, I clean the cache but this not works. I execute javaws -viewer and in the about version I have Oracle (build 1.6.0_26-b03) When I execute this file (SweetHome3D) the apps splash is the SweetHome3D but the first execute the java spalsh is the Oracle. I execute this dpkg -l | grep "java" and this is the software in my machine ii ca-certificates-java 20100412 Common CA certificates (JKS keystore) |
Current timezone is GMT Sep 6, 2026, 10:15:56 AM |
