Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Ceiling with different levels |
| Print at Sep 21, 2026, 2:43:59 AM | View all posts in this thread on one page |
| Posted by connomar at Aug 13, 2011, 11:15:22 AM |
Ceiling with different levels Hi, Is there a way of handling a ceiling that has heating ducts running under it? In this case, my basement has 1/3 of the height lower than the rest to accommodate the drop. If I set the walls at each end to the correct heights (splitting) I seem to confuse everything. I get sloping ceilings but of course I need squared surfaces. i.e. -----|_____|----- if that makes sense. Any ideas? Martin |
| Posted by hansmex at Aug 13, 2011, 11:59:27 AM |
Re: Ceiling with different levels Martin, There is a quick and easy way: - Take a box, give it the right dimensions, and place it underneath the ceiling. If you want a "real" ceiling to behave in such a way, you have to do a lot of work using - a - extra walls, made invisible by using transparent textures (gives a bad result) or better - b - the construction method for multiple level houses (PDF) Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by connomar at Aug 13, 2011, 12:52:51 PM |
Re: Ceiling with different levels Thanks Hans, I thought I could rely on you for an answer. |
Current timezone is GMT Sep 21, 2026, 2:43:59 AM |
