Print at Sep 19, 2026, 6:21:26 PM
Posted by Mitsaki at Aug 3, 2011, 7:44:09 PM
confused   Problem in Running SH3D
I am using Mac OS X (10.7 Lion) and I just download SH3D 3.3. I have read the README file of source code (of SH3D 3.3) and I am just following the instructions. After I "run configurations", I expected to have sweet home3d open. Instead, Eclipse Platform is opened. I also tried to "run java application" where SH3D is about to be opened but unfortunately without success. What am I doing wrong? Isn't it supposed to open SH3D without any problem? sad
I am desperate!
Posted by Puybaret at Aug 3, 2011, 8:35:19 PM
Re: Problem in Running SH3D
I guess you should learn how to use Eclipse first...
Posted by Mitsaki at Aug 3, 2011, 8:56:35 PM
I am trying...
Posted by Mitsaki at Aug 4, 2011, 1:47:17 PM
Well, I try to run java application with SweetHome3D - com.eteks.sweethome3d and It does not load the program? I don't know what to do. Isn't it the right way to run SH3D?
Posted by Mitsaki at Aug 4, 2011, 5:43:20 PM
That is the message that is displayed:(
Exception in thread "main" java.lang.SecurityException: sealing violation: package javax.media.j3d is sealed
at java.net.URLClassLoader.defineClass(URLClassLoader.java:234)
at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at com.eteks.sweethome3d.j3d.Component3DManager.setRenderingErrorObserver(Component3DManager.java:104)
at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(SweetHome3D.java:491)
at com.eteks.sweethome3d.SweetHome3D.init(SweetHome3D.java:383)
at com.eteks.sweethome3d.SweetHome3D.main(SweetHome3D.java:287)
Posted by Puybaret at Aug 4, 2011, 7:07:00 PM
It feels like you missed the part of the README.TXT speaking about -Djava.ext.dirs. Come on, it's not so long to read entirely, is it? sad
Posted by Mitsaki at Aug 4, 2011, 8:06:34 PM
I have done it already! It still has a problem!!!!!!!!!!!!!!!!!!!
Posted by Puybaret at Aug 4, 2011, 8:20:10 PM
What did you enter in VM arguments text field in the Eclipse Run configuration?
Posted by Mitsaki at Aug 5, 2011, 9:40:06 AM
What the README says, exactly this one:
-Djava.ext.dirs=lib:lib/macosx
Posted by Puybaret at Aug 5, 2011, 11:22:51 AM
I just tried successfully under Lion with the JDK that was automatically installed.
You error happens because the Java3D 1.5.2 libraries cited in java.ext.dirs are not found, then Sweet Home 3D uses the default Java3D 1.3 found in /System/Library/Java/Extensions/.
As lib and lib/macosx are relative paths, this probably means they are relative to the project root in the configuration you run. Replacing these paths by absolute paths should fix the problem.
