Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Can't find the plugin folder |
| Print at Sep 6, 2026, 10:37:12 AM | |
| Posted by Cardinal at Jul 27, 2011, 11:08:17 AM |
Can't find the plugin folder Hello, I'm using version 3.3 on Windows 7. I have looked for the following path : C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\plugins but under the Sweet Home 3D folder I have two other folders "work" and "recovery" along with "preferences.xml" and nothing for plugins. Thanks for your help. |
| Posted by Puybaret at Jul 27, 2011, 11:14:22 AM |
Re: Can't find the plugin folder plugins folder is created if needed when the user installs a plug-in (the same behavior applies to furniture, textures and languages folders where sh3f, sh3t and sh3l files are stored). You can create it yourself if you want to. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Cardinal at Jul 27, 2011, 3:07:43 PM |
Re: Can't find the plugin folder Thanks for your answer Puybaret. I created the plugins folder and put a test plugin I wrote (a JAR file), but it's not read by SH3D when I run it. So I downloaded some plugin to double check and it worked. However, that plugin had a ".sh3p" extension. What's the diffrenece between a JAR plugin and a .sh3p plugin and how do I make one? Thanks. |
| Posted by Cardinal at Jul 27, 2011, 3:29:02 PM |
Re: Can't find the plugin folder I also tried to test with the VolumePlugin from the tutorial to make sure I get everything right, but in the PluginAction.execute() method eclipse can not resolve the call to getHome(). And indeed I couldn't see where that method is declared? Thanks in advance. |
| Posted by Cardinal at Jul 27, 2011, 3:30:55 PM |
Re: Can't find the plugin folder Ah, it's an inner class. Sorry. |
| Posted by Cardinal at Jul 27, 2011, 3:38:53 PM |
Re: Can't find the plugin folder I finished creating the VolumePlugin, exported to JAR, changed extension to sh3p and run. I got the message saying the plugin will work in the next run but there's nothing new in the menu :( |
| Posted by Cardinal at Jul 27, 2011, 4:14:40 PM |
Re: Can't find the plugin folder I solved the problem. I was exporting with the wrong options. Sorry for spamming. |
| Posted by Puybaret at Jul 27, 2011, 8:34:28 PM |
Re: Can't find the plugin folder Great you found out! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 10:37:12 AM |
