Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Invisible cylinder |
| Print at Sep 26, 2026, 6:29:57 PM | |
| Posted by polo2010 at Jun 29, 2011, 5:30:53 AM |
Invisible cylinderI am using the invisible box and now try to do a similar one but as a invisible cylinder - I check the box mtl and obj, compare the invisible box's mtl and obj, now how to do an invisible cylinder? |
| Posted by Puybaret at Jun 29, 2011, 6:22:49 AM |
Re: Invisible cylinder In a mtl file, the number following d matches how transparent is a material from 0 (fully transparent) to 1 (fully opaque). You can try on a cylinder but don't expect to make round holes in walls with such an object. If this was your final goal, see this thread for a workaround. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by polo2010 at Jul 4, 2011, 9:40:46 AM |
Re: Invisible cylinder I am trying the work around. I don't want a round whole in the wall - I am using the "wall" to create a 20 cm thick 300 x 500 ceiling and place the new "round tool" 10x10 so I get a series of small round wholes. I copy as new furniture and elevate to my ceiling height. Then I give texture and place small light bulbs inside the small wholes to get an embedded light source, that you often see in ceilings and canopys in interior design magazines. I am not good at adding light sources, but it seems to come out fine. |
Current timezone is GMT Sep 26, 2026, 6:29:57 PM |
