Print at Sep 27, 2026, 9:01:55 PM
Posted by 100matolog at Jun 19, 2011, 10:14:44 PM
How do I change the angle to the wall was less than 15 degrees?
Posted by hansmex at Jun 19, 2011, 10:40:31 PM
Re: How do I change the angle to the wall was less than 15 degrees?
If you hold down the SHIFT key while drawing a wall you can draw walls at any angle.
You can also disable Magnetism in the Preferences, but then you can't insert doors/windows anymore.
Posted by 100matolog at Jun 20, 2011, 7:08:59 AM
Thanks
Posted by TorQueMoD at Nov 20, 2019, 12:22:35 AM
You need to hold down ALT as of version 6.1.2, not shift.
Posted by Puybaret at Nov 20, 2019, 8:49:55 AM
The magnetism shortcut changed to Alt (cmd under macOS) with version 4.0 in 2013, after this thread was started. Thanks for reporting the change even a long time after.
