Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Is possible to disable loading the basic and default furniture library? |
| Print at Sep 19, 2026, 6:49:22 PM | |
| Posted by comp001 at Jun 19, 2011, 8:16:39 PM |
Is possible to disable loading the basic and default furniture library? Hello to everybody! I'd like to now whether is possible to disable the load of the default furniture set. I'll explain my situation first. I'd like to use the program to allow the user only a few furniture, the one I've created, but I still have the load of the default library with the kitchen, living-room furniture, etcetera. Is there any possibility of disabling that library?. Ok, I know that I can import my own library to the program but for avoiding the user to get confused, I prefer Sweet Home to load only my library. Thanks in advance. Luis, Spain. |
| Posted by Puybaret at Jun 19, 2011, 9:35:08 PM |
Re: Is possible to disable loading the basic and default furniture library? If you're able to build Sweet Home 3D from the sources as indicated in the README.TXT file, you should remove lines in the Ant build.xml file that includes or moves the "build/Furniture.jar" file according to the kind of installer you want to build (for example if you want to build a Windows installer, you should remove the line 423). If you're not able to do that, you can remove from an installed version the Furniture.jar file found in the installed folder. Caution: if you want to distribute a modified version of Sweet Home 3D, its GNU General Public License obliges you to distribute the source code of the modified version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by comp001 at Jun 19, 2011, 9:43:58 PM |
Re: Is possible to disable loading the basic and default furniture library? Thanks! I'll try and tell you the results. Of course I will distribute the modified code too with the program, no problems!. Thanks. Luis |
| Posted by comp001 at Jun 19, 2011, 9:49:17 PM |
Re: Is possible to disable loading the basic and default furniture library? I removed the furniture.jar and worked perfectly for me so no code-modifications needed!. Thanks again!. Luis |
Current timezone is GMT Sep 19, 2026, 6:49:22 PM |
