Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Create "upside-down" sloped walls |
| Print at Oct 6, 2026, 10:03:35 AM | |
| Posted by Mitch at May 25, 2011, 9:10:24 PM |
Create "upside-down" sloped walls I want to try to make a wall with a sloping side. I found the slope options in the Modify screen of a wall. But it seems I can only make sloped walls that are wide at the bottom and narrow at the top. I can make a wall like this: |XX\But I want something like this: |XXXXX/Is this possible? |
| Posted by Puybaret at May 25, 2011, 9:24:07 PM |
Re: Create "upside-down" sloped walls It's not possible. But you can import a triangle placed beside a box to simulate the same thing. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at May 25, 2011, 9:29:28 PM |
Re: Create "upside-down" sloped walls Mitch, Or you can draw the wall in its upright position, then use the CopyAsNewFurniture plug-in, then Export to OBJ format, then Import furniture and turn it 180 degrees during importing. See the Sloping roof manual (PDF) for more info on this workaround. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Mitch at May 26, 2011, 8:22:16 PM |
Re: Create "upside-down" sloped walls Thanks for the answers. I tried the "triangle" approach and that worked fine. |
Current timezone is GMT Oct 6, 2026, 10:03:35 AM |
