Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: reconnect split walls |
| Print at Sep 11, 2026, 9:12:46 AM | |
| Posted by mga56grg at May 12, 2011, 6:03:00 PM |
reconnect split walls Is it possible to reconnect walls that have been split, or were originally created individually? |
| Posted by hansmex at May 12, 2011, 6:27:21 PM |
Re: reconnect split walls Marshall, 1 - Connect two walls If you install the AdvancedEdit plug-in (see manual PDF) you can connect two walls, giving them an "elastic" connection. Corners will be closed, and if necessary beveled. 2 - (Re-)Connect split walls A split wall is still connected (see 1). You cannot make one continuous wall from two wall sections. Once a wall is split, it cannot be re-joined. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 11, 2026, 9:12:46 AM |
