Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Full-HD Settings... |
| Print at Sep 9, 2026, 10:42:14 PM | View all posts in this thread on one page |
| Posted by macfrog at May 8, 2011, 11:20:46 PM |
Full-HD Settings... Hi. I would like to have a "Full-HD"-Setting preset in the Create-Photo dialog. Also, it would be nice, if the 3d-view window could be "set" or "force" to use the settings used in the mentioned dialog. (it's quite hard to set the window to a size corresponding to a special size when "use 3dview proportions" is used in the create-photo dialog.) macfrog |
| Posted by Puybaret at May 9, 2011, 7:55:18 PM |
Re: Full-HD Settings... I would like to have a "Full-HD"-Setting preset in the Create-Photo dialog. What do you mean by "Full-HD"? An additional quality level?Also, it would be nice, if the 3d-view window could be "set" or "force" to use the settings used in the mentioned dialog. I see what you mean but I'm not sure it's worth an additional button. Any other idea: I could append to the 3D view label of the Apply proportions combo box an information about the current proportion (4/3, 16/9...).---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by macfrog at May 25, 2011, 7:40:23 PM |
Re: Full-HD Settings... Hello, Full-HD would mean 1920x1080 resolution. Aspect should be the same as 16/9. greets macfrog |
Current timezone is GMT Sep 9, 2026, 10:42:14 PM |
