Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: lost everything |
| Print at Sep 6, 2026, 9:00:38 AM | |
| Posted by vinnyk at Apr 30, 2011, 11:18:16 AM |
lost everything as a new starter I did a floor plan of my house and added the furniture etc but near the end everything just disappeared !!! I must have clicked something but I dont remember what...........any help/advice would be welcome. I use win 7. thanks vinnyk |
| Posted by Puybaret at Apr 30, 2011, 12:40:12 PM |
Re: lost everything What version do you use? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by vinnyk at May 1, 2011, 2:05:04 PM |
Re: lost everything just had a look and it is 3.1 is this any help |
| Posted by vinnyk at May 1, 2011, 6:13:18 PM |
Re: lost everything as a more detailed explanation when I say everything has disappeared the plan is now just plain white with nothing else, no graph or furnishing etc that were imported ............ just nothing !!! vinnyk |
| Posted by Puybaret at May 1, 2011, 6:19:10 PM |
Re: lost everything Send it to me, I'll see if I can recover it. To other readers, be sure to always use the latest version of Sweet Home 3D. Among the "other minor bug fixes" cited in history, there are often changes that should avoid the kind of problem reported by vinnyk. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at May 1, 2011, 7:36:00 PM |
Re: lost everything I was able to fix vinnyk's issue. It was probably because of a very thin 3D model he imported, and actually, I made some small changes in version 3.2 to avoid such problems. Hopefully, the same kind of issue shouldn't happen again. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by vinnyk at May 2, 2011, 9:58:15 AM |
Re: lost everything once again thanks to Emmanuel for the help |
| Posted by lu180 at Jan 19, 2013, 4:43:19 AM |
Re: lost everything Help! I was using the online version and lost everything as well. White screen and no graph. |
| Posted by Puybaret at Jan 19, 2013, 4:45:40 PM |
Re: lost everything Lu180, I fixed the file that was wrong, but I had to remove 3 incorrect walls and a door frame. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 9:00:38 AM |
