Print at Sep 19, 2026, 8:45:04 PM View all posts in this thread on one page
Posted by rino63 at Apr 26, 2011, 2:40:15 PM
error when compiling with eclipse
hi,when I try to compile with eclipse I have this error
Exception in thread "main" java.lang.UnsatisfiedLinkError: no j3dcore-ogl in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at javax.media.j3d.NativePipeline$1.run(NativePipeline.java:231)
at java.security.AccessController.doPrivileged(Native Method)
at javax.media.j3d.NativePipeline.loadLibrary(NativePipeline.java:200)
at javax.media.j3d.NativePipeline.loadLibraries(NativePipeline.java:157)
at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:987)
at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299)
at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:321)
at java.awt.GraphicsDevice.getBestConfiguration(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:67)
at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:82)
at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(SweetHome3D.java:491)
at com.eteks.sweethome3d.SweetHome3D.init(SweetHome3D.java:383)
at com.eteks.sweethome3d.SweetHome3D.main(SweetHome3D.java:287)
please someone know why this?
thank you :)
Posted by Puybaret at Apr 26, 2011, 8:00:16 PM
Re: error when compiling with eclipse
Generally, it's because you didn't read the README.TXT file coming with the sources...
Posted by rino63 at Apr 27, 2011, 3:37:31 PM
thank you :) now work. I have changed aa.max from 2 to 4 as value and I see that the rendering time is very high on a little image. in the test image I see that when aa.max=4 there is a little black point. now I go for render a more complex image. I think this evening (or tomorrow....) I'll have something for to compare the images. if the result will be good probably I'll go to study the code(but I haven't many time for the next couple of months..) for insert a customizable aa.max in the photo window.
Posted by rino63 at Apr 28, 2011, 2:37:16 PM
rendering of an 3000x1459 pixels image started this night at the 3A.M. now are 1.38 P.M. and run.... I think 24 hours for this rendering. probably is too much slow....
Posted by rino63 at Apr 29, 2011, 2:08:46 AM
end of the rendering. the result is absolutely bad. the same image rendered with photorender classic with aa.max=2 and aa.max=4 is out of focus for both cases. with the advanced rendering plugin is sharp but not enough smooth and need a bit of more aa...:(
Posted by Puybaret at Apr 29, 2011, 10:32:24 AM
You should know that db4tech and I spent a lot of time last year to set the values that would make SunFlow renderer work reasonably well. wink
But if you still want to play with renderer quality settings, the next step should be to increase samples parameter in PhotoRenderer class.
By the way, it would be nice to post images to let us see what you get. smile
Posted by rino63 at Apr 29, 2011, 4:11:14 PM
here a 100% crop of the same zone. the first one is the advanced photorendering. the second one is the classic photo of SH(3.1) best quality aa.max=2(as in the downloaded source). the last is the rendering with SH3.2 aa.max=4
http://www.mediafire.com/imageview.php?quickkey=jp70y8v3my90m8a&thumb=4
Posted by db4tech at Apr 30, 2011, 1:02:40 AM
Hi rino63,
Just a real quick reply due to degree work to try and help.
Please check and see if you have 'Depth of field' accidentally selected instead of 'Default' in the internal 'Create photo...' render settings, hopefully this will help fix the blurry renders.
Thank you,
David
Posted by rino63 at Apr 30, 2011, 7:48:30 AM
hi david,effectively i have depth of field as camera type..if this is the problem tomorrow I try another rendering with default settings. but I don't understand in other test before this the dof work normally....
another little question: if I wish set the smooth for the room(as in blender but for all the furniture) someone could tell me what I can see in the code?
thank you
rino
Posted by Puybaret at Apr 30, 2011, 9:58:41 AM
"Depth of field" lens in Sweet Home 3D matches thinless SunFlow camera. Currently, focus is always at 250 cm from camera, so rendered objects may look blurred or sharp depending on where you placed the camera.
If you want to make smooth 3D models at OBJ format, the easiest way is to open the OBJ file with a text editor and replace "s off" lines by "s 1". In Blender, there's an Auto smooth option but I never saw it work (I don't use Blender that much too).
