Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Plugin - Creating Objects with other Properties |
| Print at Jul 22, 2026, 12:31:44 PM |
| Posted by Byron at Apr 16, 2011, 6:50:32 PM |
Plugin - Creating Objects with other Properties Dear SH3D Community, I am a student and I am supposed to create new Objects for SweetHome3D.These Objects should be extended in terms of their properties. E.g. a field center of mass or other object specific modifiable information should be added. (Actually the important part is to capture the joint and link configuration using unified robot description format (URDF)). Therefore I would like to do this by writing an effective Plugin, but I am not sure whether this is possible. The tasks which I need are the following: 1) Reading in data from a meta-file e.g. in xml which contains the information. (This I should be able to do without problems) The xml will contain all information about: joint configuration, path of the according dae-files, ... 2)Creating new Catalog-Categories and the Catalog-Object from this file and its information. 3)Being able to drag an drop this new objects to the floor plan and them being displayed in the 3D-View. (This new object should have new property fields as Center of mass in its property window then). How would you advise me to proceed? Is it possible using a plugin or not, since I might need to extend the class of PieceOfFurniture by more property-fields. Regards Byron |
| Posted by Byron at Apr 18, 2011, 7:09:19 PM |
Re: Plugin - Creating Objects with other Properties Update: I have figured how to use my plugin to create new Catalog-Elements. When I drag and drop a new item on my plan, how can I control it without changing the SH3D code? It will be added as HomePieceOfFurniture, but I want it to be added e.g. as a selfmade class *** extends HomePieceOfFurniture. Also I want to modify its properties window. How can I access the HomeController and its View from my plugin workspace? |
| Posted by alied at Apr 18, 2011, 8:33:47 PM |
Re: Plugin - Creating Objects with other Properties how can I control it without changing the SH3D code? you can add a listener to your Home object[1], then create your custom PieceOfFurniture, delete the original, and add yours (remember either remove your listener before adding your object, or check before if it's your item, or you can get into a infinite loop) Also I want to modify its properties window. That will be more complicated: You can start extending com.eteks.sweethome3d.swing.HomeFurniturePanel[2], then search in com.eteks.sweethome3d.swing.PlanComponent[3] and there should be where to change(as far as I know SH3D, you will have to modify the code) to check the selected items and show your custom dialog. Anyway, Emanuel can provide more details (and if I find something usefull, I'll tell you) Best of luck Alied [1]http://www.sweethome3d.com/javadoc/com/eteks/...model.CollectionListener) [2]http://www.sweethome3d.com/javadoc/com/eteks/...g/HomeFurniturePanel.html [3]http://www.sweethome3d.com/javadoc/com/eteks/.../swing/PlanComponent.html |
| Posted by Puybaret at Apr 18, 2011, 10:01:58 PM |
Re: Plugin - Creating Objects with other Properties A plug-in doesn't let you specify the class of pieces of furniture that should be used, and even if you create a derived version of Sweet Home 3D, it won't be so easy to perform without changing code, because furniture instantiation is done at this moment in HomeController, ImportedFurnitureWizardController and FurnitureCatalogTransferHandler. Sincerely, this is something I'm not proud of, and instantiating furniture objects in only one method that could be overridden (like i did for Wall, Room and DimensionLine classes) has been on my TODO list for a while... As for controllers and views you don't have access to them in plug-ins too, so you should probably better create a derived version of Sweet Home 3D. Creating such a version without modifying code source is completely possible, since it's the way I do it when I create customized versions of Sweet Home 3D for projects like this one. If you want more details, you know the place where you can ask questions... ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Byron at Apr 20, 2011, 11:33:04 PM |
Re: Plugin - Creating Objects with other Properties Ok thanks for your input, it is good to know what is possible and what is not. I have started working on a derived version already, I would have loved to somehow utilize the plugin feature in order to not mess up the code of this nice programm. I'll continue and will update, as soon as I have some nice results. |
| Posted by alied at Apr 21, 2011, 8:50:16 PM |
Re: Plugin - Creating Objects with other Properties Still, there is something you can do without messing with the code. in your Plugin constructor, get the Home and add a listener: Next, create a PluginAction which shows your properties dialog (which you might extend from com.eteks.sweethome3d.swing.HomeFurniturePanel if you are interesred in) iff the selected items(s) are of your class. I hope this can hep you. |
| Posted by Puybaret at Apr 21, 2011, 9:06:37 PM |
Re: Plugin - Creating Objects with other Properties alied's tip is good but I just have some doubts about classpath when opening homes with substituted objects, and how undo/redo will work when you substitute an object by an other one. At the minimum you should take care of the index of the added piece. An other tip is to manage all your additional information with setVisualProperty/getVisualProperty methods available in Home class. It won't be a very clean architecture, but will work out of the box if you store there only standard class instances. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Byron at Apr 23, 2011, 3:51:45 PM |
Re: Plugin - Creating Objects with other Properties Thanks for these tipps, I have worked around the topic and have added a new HomeURDFObject class in my plugin. Unfortunately I had to change some stuff in the code, but I tried to keep it as little as possible. Also I added a new Panel class for that which I will simply add to the normal property panel. I think I will finish this work soon, if interested I will post the steps which were important. But the thing is, that I already worked on a extended version of SH3D. But Ill tell you! ;) |
| Posted by Puybaret at Apr 23, 2011, 5:14:55 PM |
Re: Plugin - Creating Objects with other Properties Please share your findings with the community. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sicodelicos2003 at Jul 7, 2011, 2:34:08 AM |
Re: Plugin - Creating Objects with other Properties Please share your findings with the community. ![]() Hello. My name is Nicolas, i'm from Argentina. I'm starting with SH3D. I have to design a furniture with some special properties. Can you share your results? This is for my undergraduate thesis (Mobile information systems). PD: sorry my english, i don't speak the language well. Thanks from now |
Current timezone is GMT Jul 22, 2026, 12:31:44 PM |
