Print at Sep 19, 2026, 6:07:43 PM View all posts in this thread on one page
Posted by rahul18bisht at Apr 13, 2011, 1:00:57 PM
how to modify existing walls exterior and interior walls at 90 degrees only ?
how to modify existing walls at floor planner, both exterior and interior walls at 90 degrees only ?
I have a problem that, when I modify walls at floor planner, it get modified at any angle at any degrees , which I have to restrict it, to degrees degrees , so that if we modify walls exterior or interior walls , it should modify at 90 degrees only or parallel only.
Please help me and provide solution to this problem or suggests existing function to look, to impose conditions and what condition to put ?
Posted by hansmex at Apr 13, 2011, 1:33:16 PM
Re: how to modify existing walls exterior and interior walls at 90 degrees only ?
Rahul,
When you have drawn a wall, you can easily rotate it. Place the mouce on the handle at the end of the wall and drag it. The wall will rotate in 15 degree increments. This makes it very easy to get a 90 degree rotation.
Posted by rahul18bisht at Apr 13, 2011, 3:50:48 PM
which method to look sir ? to make modification of existing walls once created at 90 degrees only ??
