Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: apply texture only on a piece of an object |
| Print at Sep 20, 2026, 6:17:38 PM | |
| Posted by rino63 at Apr 11, 2011, 12:04:15 PM |
apply texture only on a piece of an object hi, when I apply a texture on an object, for example a bed, the texture is applied on the entire bed not only a piece. better explaination: if the bed have the support of iron, the final result after the texture application should be the texture (example wood) on the structure and the support should be iron. is this result possible or I need edit the model with a modeller? gennaro |
| Posted by hansmex at Apr 11, 2011, 12:17:07 PM |
Re: apply texture only on a piece of an object Gennaro, You guessed right: if you want partial textures, you will have to use a modeller like Art of Illusion or Blender. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 6:17:38 PM |
